allentot wrote:and to add dave, my engine heats up alot since we put the carb (solex 40) in it even in the first place...
When you put the carb on, what temperature sender unit (bottom of intake manifold) did you use? The one on the original manifold or the one on the side draught manifold?
If the temperature sender is different maybe this could explain some of the motor temp problem?
Also, the thermostat, is it new, old or same as what the car had before?
allentot wrote:my engine runs without any problem before we replaced the carb and the solex 40 we just put in was never been rebuild before and it was sitting in my friends garage for quite a long time...
Have you checked the float level in the carb? and I also wonder the condition of the gaskets?
allentot wrote:regarding the gasket, i just finished this morning checking my plugs for coolant leaks and there wasn't any trace of it on my plugs and my exhaust isn't experiencing smoke or drips of water in its tip..
I imagine you also checked for coolant in the oil and oil in the coolant? And for bubbles on the bottom of the dipstick?
Sorry, I have more questions then answers
Just added:
tango76hardtop wrote:Sounds like the carby is your problem seeings thats with the stock carby it was fine and problems only started when you used the solex 40. when a carby has been sitting in a shed for a while they tend to need a rebuild to run right, you should try rebuilding the carby and tuning it and use the stock carb in the meantime or maybe even swap and leave your stock carby on it.
I was also wondering if it was worth changing the carby back to see if it fixed the problem? At least that way it may eliminate the new carb as the source of the problem?
