brake upgrade
brake upgrade
After a brake updrage something i can bolt straight into my gc in in an hour or 2 no modifications needes haha that are bigger and better brakes
Re: brake upgrade
Y r u needing bigger brakes first of all?????
Are u fitting a bigger engine?????
As far I can see u have 3 options:
1) you use slotted/drilled rotors, performance pads, fluid and steel braided lines
2) there has been a lot of chatter about using Sigma components that can be useful
3) Hoppers Stoppers has a bolt in brakes upgrade for our cars (minimum 15" wheels needed)
Re: brake upgrade
Fitting a 2L sigma and dont wanna fuck around with brakes personally dont wanna do it hahah
Re: brake upgrade
If ur really budget conscious, option 2 is best
If your happy to pour money, option 1 is best
Re: brake upgrade
Standard GC brakes should be fine if in good condition ... the 2L was the stock motor in them in Japan, remember! GC/GD Galant run the same front brakes as GE Sigma anyway.
Put some decent pads & shoes on it, and replace your brake hoses (including the one from body to rear axle) ..... even new rubber hoses make a massive difference compared to ones that are 40 years old !
Re: brake upgrade
Is that good enough for an engineer though? (I'm thinking rego).davetrees wrote:the 2L was the stock motor in them in Japan, remember! GC/GD Galant run the same front brakes as GE Sigma anyway.
Has anyone in NSW ever got a 2 litre in a Galant through rego before? I've never heard of it, as everyone goes straight for the 2.6.
Re: brake upgrade
Don't see why you couldn't ....... as I understand it the Australian factory workshop manual for the GC actually lists the 2L motor as an option, even though it was never released in Australia that way ? (same way the Chrysler Australia manual for the 4G32 motor shows the twincarb / GS version .... it's a re-covered copy of the Jap manual))
As long as the car passed the brake test it would be fine anyway, wouldn't it ?
Re: brake upgrade
I am gunna work the shit outta it n/a and yer planning on replacing fronts as rear has been replaced
Re: brake upgrade
I am very happy with my Rebuilt Standard calipers with a half decent set of pads and slotted and dimpled rotors. they put up with a fair bit of abuse before they fade.
rebuild kit and hone probably cost less than $50 all up, pads i had sitting around so cant recall what they cost and my rotors i got off of ebay for around the $160 mark.
VGJONO
VGJONO
Re: brake upgrade
I dont have a brake booster and dont plan on getting one so would like the bigger Breaks haha
Re: brake upgrade
You won't feel any difference in pedal feel if u dont increase the volume inside the calipers/brake master cylinder/wheel cylinders.
- karl_2ltgc
Re: brake upgrade
GH sigma brakes bolt in if you swap the entire strut. I did it on my car about 10 years ago. 256mm rotors and pads are cheap as they are the same as early commodores.
Re: brake upgrade
In the ACT you'd never get it through rego without an engineering certificate, due to the engine number they will find out its not the factory engine for the car, you'll get recalled to go in and they will fail you for heaps, as for NSW I'm not sure, they'll most likely pull you up on it but theres a chance you can get away with it..
Cheers, Brendan.
