Any help would be greatly appreciated
VGJONO
+1 on that. The higher the RPM, the more the coil struggles to deliver adequate spark. Once the coil starts breaking down, it'll cause misfires. Its probably causing it to run a little rich too if the spark is poor at lower RPM. I'd be getting a new coil (if you haven't already and you can cross this off the list as being a possible fault). Maybe it's time to upgrade to a Bosch "T" coil?davetrees wrote:Coil ? It's one thing you don't mention in your original post ... and they can cause those sorts of issues if tired (ie. fine until put under heavy load & having to regenerate spark very quickly at higher rpm)
