What Webber is this?
HEMI26
Post by HEMI26 »
Hi ppl im just woundering what type of weber carb this is if anyone can tell it will be a great help as im not sure what type it is and all the carby blokes i know are v8 lovers, its on a worked 4g54 and was tweaked by the old owner and made good power. cheers dave
here's a pic of the carb
Current Cars
-VQ SV90 #098 (Finished)
Some Old cars
-RX8
-VQ (Slammed on 19's)
astronturbo77
Re: What Webber is this?
Post by astronturbo77 »
thats a 32/36 weber, looks identical to the one i got from a 4 cylinder centura with the pergueot engine. these are slightly different to the cortina one i believe..
It's not Mark :P
woops
Post by woops »
Does it definitely say Weber on the carbie? I know that there was also a 180 holley which was essentially a copy of the weber too. I have one on a parts car down the back that looks to be exactly the same as your carb.
TVM006
Post by TVM006 »
Yeah i agree with 'woops' looks like a 180 holley which is equivalent to a 32/36 weber anyway.
TVMDouble0h!Sixx
1985 GK GSR
HEMI26
Post by HEMI26 »
deff says weber on it on the pump bit, but it is a part that can be bolted on i need a closer look to see if it says weber on the base/actual carb cast
Current Cars
Some Old cars
-RX8
astronturbo77
have a look on the bottom flange where the studs go through the base plate webers always have the type of carby stamped on there.
HEMI26
Post by HEMI26 »
this is the only stamp i can see atmImage
hey man is the stamp on the side of the base or the top of it looking from above?
Current Cars
Some Old cars
-RX8
woops
Post by woops »
Take a look at the back of the carby, the side that faces the firewall and where the accelerator attaches. Up near the top would be a holley logo, well there is on mine.
HEMI26
Post by HEMI26 »
I had a good look in the day light ppl and could'nt see any holley logo's
but i did see 32/36 DFV stamped on the rocker cover side of the base Image
Current Cars
Some Old cars
-RX8
davetrees
Post by davetrees »
I was going to say it looks like a Weber 32/36 DFV ...... which is the right thing for a Saturn motor if you want this type of carb (essentially the same as a 32/36 DGV, except the primary & secondary are reversed, and the throttle works the other way compared to the DGV)
i have one on my GB rally car (which has only a lightly modified engine - a bit of head work & a better cam) and it's a good thing. A good (and very cheap) upgrade from the stock carb .... and IMHO much better bang for your buck than going the twin downdraught Solex/Mikuni route. Parts are very readily available.
davetrees wrote:and IMHO much better bang for your buck than going the twin downdraught Solex/Mikuni route. Parts are very readily available.
On that note.
Differences between:
My wagon with 4G32, No.5 cam and twin Solex/Mukini down draughts (undynotuned or properly set up)
My LC Lancer Hatch 4G32B with mid cam (specs unknown) cam advanced on tooth, and down draught weber (also undynotuned and carb jetted for 2.6).
The Hatch has better top end, and the wagon has better bottom end :think: , but in the end the hatch would eat the wagon any day of the week.
Moral to the story:
Build everything in your engine to match, get it dyno tuned and it should work well together.
Hit and miss means low $$$ but low performance also.
I plan to increase the size of the secondary jets in the twins that are on the wagon (it starves for fuel in the top end), and maybe a change of cam to something less aggressive. Then maybe finally it will get up and go?
HEMI26
Post by HEMI26 »
cheers for the great help ppl
Moral to the story:
sounds right man, my carb was tweaked n tuned by Mcdonald bro's in thomastown to suit the build of my engine they done, it made 148rwhp on there dyno with my old bottem end i blew (its currently a std a2 bottem end now), i dont kno if it was great power for that eng but it done the job and was pritty qwick then 6yrs ago!!!
Current Cars
Some Old cars
-RX8
davetrees
Post by davetrees »
75wagon wrote: I plan to increase the size of the secondary jets in the twins that are on the wagon (it starves for fuel in the top end), and maybe a change of cam to something less aggressive. Then maybe finally it will get up and go?
I have long considered (but have never got around to) putting a twin downdraught manifold on mine, with a PAIR of 32/36 DFVs.
This would have the advantages of carbs that are far more tunable in terms of jetting etc than the stock Mikunis, and getting away from the vacuum-operated secondaries. In theory, it should be a really good option ... especially paired with say a #2 cam.
tandanus
Post by tandanus »
IIRC if you want to bolt a down-draught Weber onto a stock 1600 you could use a 32/34 DMTL (LandRover/Golf). Trouble us, parts seem to be NLA.
T.
John Ruskin
HEMI26
Post by HEMI26 »
does anybody know what the dfv carb came out on?
Current Cars
Some Old cars
-RX8
This doesn't say what they were factory fitted to but it is a good read.
http://datsun1200.com/modules/mediawiki ... Carburetor
HEMI26
Post by HEMI26 »
Cheers man :thumpsup:
Current Cars
Some Old cars
-RX8
davetrees
Post by davetrees »
HEMI26 wrote:does anybody know what the dfv carb came out on?
Not 100% sure, but I think the 2L Ford Capri (Pinto engined)? (The 2L Escorts had a 32/36 DGV IIRC, not sure whether the 2L Cortina had a DGV or DFV)
Another workable option on a stock Saturn could be the 32DIR ..... very similar carb to the DFV (same baseplate, throttle works same way, etc), but both barrels have 32mm butterflies. Came out on Alfasuds, some Renaults & suchlike.
astronturbo77
astronturbo77 wrote:have a look on the bottom flange where the studs go through the base plate webers always have the type of carby stamped on there.
HEMI26 wrote:I had a good look in the day light ppl and could'nt see any holley logo's
good stuff, this was the location i was trying to explain :$
HEMI26
Post by HEMI26 »
dam they make em hard to find :|
Current Cars
Some Old cars
-RX8
trainzkid88
Post by trainzkid88 »
the 2l 79 rs2000 escort did have a 32/36 dfv weber fitted i know as dad had one. i wish he hadn't sold it cause the new owner blew it up doing burnouts.
PROSSER
Post by PROSSER »
Galant_GT0 wrote:It's not Mark :P
Your my hero I've wanted to throw thus up a couple of times you got to love sly humour.
Samual
