Changing the head gasket without removing the head is a snack when compared to changing the spark plugs with a factory turbo exhaust manifold in place. Got some NGK Platinum's waiting to go in.
Sigmaproject wrote:Yes I was kidding ;) But not about the head gasket, that pretty hard to do![]()
Only problem is no2 behind the turbo. I usually use an old plug lead , put the new plug into the old lead and wind it in with the lead. Just to get it started at least.
I also use the aluminium paste anti seize.
are you thinking of tims car?Cottees wrote:A friend has a Mitsubishi 3000GT with DOHC 6G72.
Ah yeah, I have done that a couple times already.webby wrote:changing plugs on a v6 commodore while the engine's hot ;)
mic_77 wrote:Replacing turbo's and manifolds in a r33 gtr with the motor in the car absolute nightmare.
cheers Mic
I would take it you are referring to a classic Saab 900? Those are great fun - not! Changing alternator/power steering/AC belts on thise is a bitch too. North-south engine but the timing chain end faces the firewall. Not a lot of room between engine and firewall. All very "hurdy gurdy"And doing an Auto rebuild on a SAAB, where the Auto is actually the Sump of the Engine
mitsugalant wrote:I would take it you are referring to a classic Saab 900? Those are great fun - not! Changing alternator/power steering/AC belts on thise is a bitch too. North-south engine but the timing chain end faces the firewall. Not a lot of room between engine and firewall. All very "hurdy gurdy"And doing an Auto rebuild on a SAAB, where the Auto is actually the Sump of the Engine
Plus side is a clutch on them can be done with the engine and gearbox still in the car.
