Firmer ride for the sigma
Hi guys just curios what shocks every one is using in there sigmas i want to firmup the ride its got super low dobinson springs in and ive lready got front sway bar and done most of the bushes i just want a realy good firm shock without going coil over any help would be great thanks
84 gk sigma
Re: Firmer ride for the sigma
Commodore VB to VR will fit in your struts. Look through the better quality brands and you should find a firm shock.
I use Koni adjustable strut inserts in the front of my GH, but have found that gas shocks in the rear are much to firm. With Munro Gas GT shocks in the rear are like having 4x2 timber in place of shocks. The car jumps around bumpy corners and rides like crap. So I use standard hydraulic in the rear.
GH Sigma Turbo no. 047
- cheaterparts
yes the rears are a problem when made to hardTurbo047 wrote:I use Koni adjustable strut inserts in the front of my GH, but have found that gas shocks in the rear are much to firm. With Munro Gas GT shocks in the rear are like having 4x2 timber in place of shocks. The car jumps around bumpy corners and rides like crap. So I use standard hydraulic in the rear.
I use Koni red adjustable for a Cameria and cut the tubes down a couple of inchs that matched with some 300 lb springs and a 28 mm front sway bar
the rear I run lighter springs than std ( sorry dont remember what weight I ended up with ) and some basic pedders white shock with no rear sway bay and rubber top link bushes ( the top links work better with the softer bushes to stop bind up of the rear end )
and the other thing I removed the inner lower links the bolt from the lower link towards the diff - these also bind up the rear and makes the car over steer
I could do with a realy light rear bar as I know that the car would just lift a front wheel through some corners while hard on the gas
corner stewards have told me that at sandown it just lifts a wheel over the top of rockies and I know it also does it in the tight corner before going up the back straight
however the car is fairly well balanced and well mannered as it is
I use KYB gassies in the rear of my Galant with stock springs and they are matched pretty well to the 285lb front springs and Monroe Sensa Track Camira front struts.
Well they fit my driving style anyway, will be fun the first time I roll it out with the LSD
