whacked it on last weekend
Bit late for that I think Scorpma?Scorpma82 wrote:I like the 2nd setup....is it low enough to put the battery plater back on the car????
Would be easier to pass the cops' eye too if he can't see it
Almost low Enuff to do that but not quite, would needScorpma82 wrote:I like the 2nd setup....is it low enough to put the battery plater back on the car????
Yea was thinking of a cai.geezer101 wrote:Bit late for that I think Scorpma?Scorpma82 wrote:I like the 2nd setup....is it low enough to put the battery plater back on the car????
Would be easier to pass the cops' eye too if he can't see itI personally wouldn't go for the extended intake pipe unless it was necessary to pass around or away from something else. You're still going to need a bracket attached to it so it doesn't work its way free - and a shroud or box to duct cool air from inside the guard into the air pod would be a good idea.
