4G63
Re: 4G63
Cool, there is a cheap HH GSR on gumtree with a broken timing belt, I will give it a miss.
- BlueThunder
Re: 4G63
In my Celeste / LB hatch, the SOHC is not interfering anything. Plug and play, just had to take the accelerator pedal for the original (Sapporo/Scorpion) throttle cable and preferably the Scorion engine mounts (engine sits higher with them so the exhaust won't interfere with the pitman-arm.
As you may have read, the intake manifold for the DOHC will interfere with the brakebooster (LH drive) and the rear waterneck is also something to look at (will interfere with the firewall)
Greetz
Sven
Greetz
Sven
![Image](http://i541.photobucket.com/albums/gg387/84GKSIG/MX/LB111-2sml.png)
Re: 4G63
Sorry Sven, by interference engine I meant will the valves foul on the pistons if the timing belt/chain breaks.
- BlueThunder
Re: 4G63
ow, sorry, my bad, i thought if it would interefere with something else in the area... :s
it's just how you look at the word "interfere" of course...
Re: 4G63
All good mate, you raised a few good points anyway ![thump :thumpsup:](./images/smilies/thumbsup.gif)
