temp and fuel gauges
hi all both the temperature and fuel gauges have died in my gj , I have replaced the fuel sender unit and the temperature sensor but still not working any help much appreciated thanks Chris.
Re: temp and fuel gauges
Broken wires??
Bad contacts???
have you checked with a 2nd guage (assuming you have one)
Bad contacts???
I have checked the connections on the dash and the fuel sender and the temperature sensor
From memory, there is a 10v 3 pin regulator (LM7810) somewhere on the back of the dash.
If it has failed, you lose the Temp and Fuel gauges. These gauges require a regulated voltage to read correctly.
thanks superscan do you get replacements at auto electricians ?
What about the circuit board behind the instrument cluster?
Jaycar have the LM7809 (9volt) regulator, you just ad a 1n4004 diode to the ground pin to get 9.7V which is close enough for the gauges to read correctly.crystalmeths wrote:thanks superscan do you get replacements at auto electricians ?
You could also just use the LM7809 but the gauges would be slightly out.
If you need any help with the circuit etc, let me know.
thanks again superscan ![thump :thumpsup:](./images/smilies/thumbsup.gif)
- turbosigma
How can you tell if this is starting to cause trouble?
'82 GJ Sigma Sedan. 2l 3 speed, stock.
Call me TD.
Call me TD.
with mine the fuel gauge just stopped working and the temperature gauge started to work only on and off for a couple of days then died
Could that 3 pin regulator be the same problem for my gh sigma my fuel gauge and temp don't work but I haven't replaced anything yet...
Chriz312 it is shear driver abuse that broke yours
Had fun finding my GJ workshop manual.
Here are a few pics.
Here is where the regulator is situated on the back of the dash.
![Image](http://110.174.47.143/SG/DASH/GJ/DASH-Voltage%20Reg.jpg)
This is a wiring diagram for the dash.
![Image](http://110.174.47.143/SG/DASH/GJ/DASH-diagram.jpg)
I have located a GJ dash and will confirm the pins are in the same order.
Left to right, looking at the writing on the case, pins facing down.
1=In (12volt)
2= Ground/earth
3=Out (10volt)
Back Plate= Ground/earth.
http://www.fairchildsemi.com/ds/LM/LM7805.pdf
Preferably use a heatsink.
I'll post some more tomorrow.
1=In (12volt)
2= Ground/earth
3=Out (10volt)
Hey all.
From memory, these regs are 'clamped' onto the cluster aren't they?
Pretty sure I remember in my GH cleaning the contacts & it all worked fine again??
-A touch and go connection would explain the erratic operation most encounter. Although if both gauges are dead, then likely regulator has failed.
Awesome Scott thanks mate ![thump :thumpsup:](./images/smilies/thumbsup.gif)
