About 6 months ago i scored a 4g54 astron II for $200.
I have since partly fitted this into my GB and am just upto doing the Brakes and suspension.
With the engine, i got some other bits such as, front strut and brake assembly,
Rear axles with hub and discs, Rear calipers and all the steering arms and what not.
The bloke i got it all off said it was all out of a GK, but im not sure of this as the GK
i seen at the wreckers had an astron I and rear drums. Did they GK come with astron II and Disc rear?
or would this more likely be GN?
Also, has anyone tried fitting the 2 bolt struts to a GB by just swapping the ball joints out for sigma ones?
and Would the axles swap out so i could then just weld a mount for the caliper.
just thought i would dip into the wealth of knowledge before i go experimenting
Daniel
