Trigger wheels???
Posted: Sat Jul 16, 2011 9:59 pm
Whats the difference between trigger wheels?
Like why would you choose a 35-1 over a 36-1?
Do they suit different systems or are the per cylinder setup or maybe engine maker?
Re: Trigger wheels???
Posted: Sun Jul 17, 2011 11:15 am
by Superscan811
It depends more on your ECU than the amount of cylinders.
The 36 -1 is the standard for the Ford EDIS wasted spark system. It's cheap, it works well and most aftermarket ECU's are able to interface with it.
Posted: Sun Jul 17, 2011 11:53 am
Cool, I am buying the Microtech MT4 from r20bear. Will a 36-1 suit this?
Posted: Mon Jul 18, 2011 9:20 pm
by amgis_obrut
just tell John what you have and he'll build the ecu to suit
ah just noticed your getting a used ecu, they can be reconfigured
http://microtechefi.com/forum/index.php
actually the Mt4 is a fuel only comp so no it wont run the crank trigger
Posted: Mon Jul 18, 2011 9:24 pm
John?
Posted: Mon Jul 18, 2011 9:28 pm
by amgis_obrut
owns microtech
Posted: Mon Jul 18, 2011 9:32 pm
Ah okay, well I am getting the MT4 fso will grab the 36-1 if it can be tuned to it. Still not sure on which injectors but I will cross that bridge in a few months, lol
Posted: Mon Jul 18, 2011 9:42 pm
by amgis_obrut
sorry Jason i did edit my post before but the MT4 is a fuel only ecu and wont run a crank trigger, you can get an lt10s ignition only comp that will do crank trigger but its $900
Imo you would be better off saving your pennies to have an ECU built to suit your needs
Posted: Mon Jul 18, 2011 9:44 pm
Cool, I have paid a deposit on the MT4 and made a promise so will give it a go.
I think I should be okay with fuel only, for now
Will the MT4 run the quads I intend to run?
Posted: Mon Jul 18, 2011 9:49 pm
by amgis_obrut
A112H wrote:Will the MT4 run the quads I intend to run?
yep
Posted: Mon Jul 18, 2011 9:51 pm
Cool, I will run with it for now and see how I go. It is pretty cheap and the loom is to suit a Asstron
