Hey guys,
Whats the best way to remove the outside chrome window trim of an lb hatch?
Its looking like I have to just yank them off... but wanted to double check before I damage anything
thanks
Removing door window chrome
Re: Removing door window chrome
i believe you have to remove the glass "hairy squeegee" with a flathead screwdriver
and the trim should be removeable (unless they've been silconed in)
- BlueThunder
as far as i can see it in the parts catalogue there is 1 clip at the aft part and 2 or 3 flange nuts on the moulding. I never removed them myself but I guess you have to remove the clip and then try to pull the strip upwards, out off the nuts. Hopefully they aren't glued on as A57C said...
![Image](http://i541.photobucket.com/albums/gg387/84GKSIG/MX/LB111-2sml.png)
If your refering to the front door outer mould there should be 3 - 4 clips that you can just see the end of when the window is down. These ones simply push off from the base with a screw driver be sure not to put too much pressure on the window as they don't take kindly to it ( if concerned remove the window ).
if its the rear curved piece there is 2 nuts and one plastic push pin at the very top wich means window and rubber need removal.
cheers Trev
cheers Trev
sweet! thanks guys.
I was talking about the front outer door one. Got it off no probs
