Page 1 of 2
Leeroy's 1980 Lancer A73 resto project
Posted: Fri May 04, 2012 5:31 pm
by Leeroy
Hey guys,
1980 lancer LC coupe/hatchback
Engine: 4g32 1600cc twin solex carburettor
Transmission: 5 speed manuel
Odometer: 70,500kms
Color: Silver
The car hasn't been started in 11 years and the interior is in pieces. So it will be a fairly big project. The engine bay needs a serious clean, it even has vintage cobwebs :P
Ill get some more exterior pics later on in the project, I'm going to focus more on the interior/engine bay first
The VETERAN engine bay!!
Standard manifold
I've started putting the interior back together, Will post more pics asap!
Old school aircon :P (mission to mount)
Re: Leeroy's 1980 Lancer A73 resto project
Posted: Fri May 04, 2012 5:34 pm
Wow, that sounds interesting?
Can't wait to see pics :thumpsup:
Posted: Fri May 04, 2012 7:07 pm
by bruggz351
Cool bananas :thumpsup:
X2 on the pics...
Posted: Sun May 06, 2012 6:52 pm
by Pre-Evo
Almost bought this one my self. Nice to see its gone to a good home.
X3 on the picks.
Posted: Wed May 09, 2012 2:33 pm
by Leeroy
After cleaning and a basic service on my engine i got the beast running! And looking a lot better then before (H)
What i did:
Firstly, I covered the carbies with a few rags and then sprayed the engine bay with a hose to get rid of all the cobwebs, spiders and some surface dirt. Following that I removed the distributor cap and spark plugs (one at a time so i didn't mix up the leads) and gave them a good clean. I used a small wire to remove majority of the carbon followed by light sand paper on the tip, then rinsing it in petrol. After that i cleaned out the air filters with a compressor, rubbed the chrome tops with steel wool which got rid of a lot of the surface rust. Futhermore, draining all fluids and flushing out the radiator, engine oil, and put a few cups of fuel in the tank and let it drain out.
Within 3 minutes of playing with the choke and pumping the accelerator the engine started!
To clean up the engine a bit i rubbed all the black pipes and the blue leads with a soapy rag, then washing down with a clean rag. I put a rust dissolver product on the extractor manifolds (didn't work too well). Then finally i scrubbed the rocker cover with steel wool to get rid of the rough surface, followed by a little bit of aluminium polish. :thumpsup:
Posted: Wed May 09, 2012 6:27 pm
It looks pretty good, what's it like for rust?
Leeroy wrote:Are these extractors? or just a standard manifold?
Just the standard manifold unfortunately.
Posted: Wed May 09, 2012 7:39 pm
by Leeroy
75wagon wrote:It looks pretty good, what's it like for rust?
Fairly good.. I actually just finished scraping back the small amount of rust off the bonnet. You can see the rust I am targeting in the photo of the car on the car trailer. I think there is a like a spec on the roof, might just treat it and dab a fraction of paint on it
I thought so, the guy who sold it said in the description it had extractors.. but oh well.. I actually took it for a drive down my street tonight. sounds meaty.
Posted: Wed May 09, 2012 8:07 pm
What about around the rear side louvers?
Take them off and have a look.
It's the first place the hatchbacks' go when they rust.
Posted: Wed May 09, 2012 8:42 pm
by Leeroy
Yer theres no rust there.. it was about 3 hours inland from the sea though, which could be a plausible explanation.
Im having trouble getting my tacho to work.. There are 8 wires coming out from the speedo/tacho/gauges and only 7 wires on the connection plug.. I followed the 8th wire and it leads to the tacho, however where would i find the wire that its suppose to connected to? where is the point of origin of this wire?
Posted: Wed May 09, 2012 8:53 pm
Leeroy wrote:where is the point of origin of this wire?
The negative side of the coil.
Posted: Wed May 09, 2012 10:02 pm
by gaPhil
Impressive change with the engine bay, looks really tidy now!
Nice ride in general, I like the silver colour.
Posted: Wed May 09, 2012 10:53 pm
by Leeroy
Ill check it out tomorrow, what does the wire usually look like?
gaPhil wrote:Impressive change with the engine bay, looks really tidy now!
Thanks Phil, I'm happy with the engine bay for now however the silver paint work has really small spots all over it. Which when polished will stand out :/ Im considering getting it resprayed but i'll have to see how my budget it going after i get it on the road
Posted: Wed May 09, 2012 11:51 pm
by orangelancer
you might need to clay bar it then. mine had white spots all over it when i bought it so i clay barred it and they came straight off
Posted: Thu May 10, 2012 9:16 am
by Leeroy
orangelancer wrote:you might need to clay bar it then. mine had white spots all over it when i bought it so i clay barred it and they came straight off
Sweet, ill definitely look into that thanks. Do you have any before after pictures of your paint work?
Posted: Thu May 10, 2012 7:34 pm
by orangelancer
yeh here
before
after
what i did was wash, claybar, wash(i cant remember if i washed after the clay bar but im pretty sure i did), cut n polish, wash and wax.
Posted: Thu May 10, 2012 7:51 pm
by Leeroy
Looks sweet!
Do you have to get a specific colour clay bar to match the colour of your car?
Posted: Fri May 11, 2012 2:15 am
by orangelancer
im pretty sure you can get any clay bar ive used both the meguirs and the mothers clay bar. Both are as good as each other
Posted: Fri May 11, 2012 8:07 am
by Leeroy
Alright sweet, I'll give it a go (H)
Posted: Mon May 21, 2012 11:12 pm
by Leeroy
Some more photos of recent work to the car
front bumper rust removal
Rust dissolver soaked in
Silver galvinizer sprayed onto effected areas
Bogged up and coated with another layer of silver gal (until i re-sand it down)
Some photos of interior
Dash lights finally working!!
Sound system
Next step. sand down bumpers, side vents and grill for respray..
Posted: Tue May 29, 2012 10:10 pm
by Leeroy
Problem:
If the car is idling with no problems, and i put my foot down on the accelerator it chokes and if kept down stalls. If i slowly compress the accelerator it revs upto red line area. Is this a carby issue or is it something else?
Posted: Wed May 30, 2012 3:27 am
by shuggy
look down the carbs and lift the throttle. you should see fuel spirt out into the throat of the primary. If not you have a accelerator pump block. Its richens up the mix when you open the throttle to stop it from leaning out. Sounds like your promlem. if it hasnt been run in 10 years you will need to take apart the carbs and clean and put new seals and gaskets in. Very easy, do one at a time, if you get stuck, take apart the second to see how its done.
Posted: Tue Jun 12, 2012 1:32 pm
by Leeroy
Just got back from my mechanics with the LC.. got a big list of things to do haha, majority of the problems were under the car, which i havent really had a good look at because i dont have a hoist..
things i need:
Blinker combo switch (snapped on the way over, grr dad)
Gear box mount is cracked
Sway bar link pin bushes
Bottom ball joints
Front brake hoses
Front break pads
Front struts
If you know where i can find any of the above it would be greatly appreciated haha
Posted: Tue Jun 12, 2012 3:51 pm
by orangelancer
Leeroy wrote:Just got back from my mechanics with the LC.. got a big list of things to do haha, majority of the problems were under the car, which i havent really had a good look at because i dont have a hoist..
things i need:
Bottom ball joints
Front brake hoses
Front break pads
Front struts
gearbox mount i got from bursons. theyre $80 brand new. as for pads these should do http://www.ebay.com.au/itm/DB85-DISC-BR ... 500wt_1413
these are the sway bar link bushes?
http://www.ebay.com.au/itm/MITSUBISHI-L ... 2458wt_914
these look like the ball joints but theyre the only ones on flee bay i could find so idk about their price of $110
http://www.ebay.com.au/itm/MITSUBISHI-G ... 737wt_1163
even though they say theyre for corollas, lancer hatches have the same part number. as for the rest give autosurplus in melbourne a call. they saved me a ton of money and had alot of the parts i needed. they do express shipping so youll have virtually next day delivery
Posted: Tue Jun 12, 2012 8:58 pm
by davetrees
If the combo switch is the same as in GC/GD Galant - no idea if they are or not - then I have a NOS one in the shed that's of no use to me unless I rewire it & change the conectors to suit a GB (I bought it thinking all the Galant ones were the same :think: )
PM me if interested & we can negotiate something ?
Posted: Tue Jun 12, 2012 9:02 pm
davetrees wrote:If the combo switch is the same as in GC/GD Galant - no idea if they are or not -
No they aren't. The blinker stalk is a headlight switch, and the other side has the wiper control.
Posted: Fri Jun 15, 2012 5:42 pm
by Leeroy
So the NOS blinker that dave has wont fit on my LC? Ive attempted a soldering/aroldyte join to try and fix the problem however I wont be suprised if it snaps again.
As for those parts i will look into them thanks orangelancer :)
Posted: Sun Jun 17, 2012 6:04 pm
by Leeroy
What shock absorbers should I buy?
I was looking at this, only because they sell individual shock absorbers and thats all I need to get it roadworthy. But im not sure if it will fit on my car.
Also what is the difference between a rear shock and a front shock?
http://www.ebay.com.au/itm/Mitsubishi-C ... 675wt_1156
Posted: Sun Jun 17, 2012 7:26 pm
by davetrees
Anywhere will sell shocks individually, but you should always replace them in pairs.
Front shocks are a sealed insert that goes inside the strut (if your struts are original, they will be oil-filled ... the shock mechanism will need to be removed, the oil drained out, and an insert put in the strut body). Rears are totally different.
If you don't know the difference (which I suspect is the case, seeing you are considering buying shocks for a completely different model car than what you have ?) then I strongly suggest you go to a suspension specialist & get them to supply & fit a set.
If you just want basic / cheap (with performance & reliability to match) .... just go to your nearest Pedders outlet and buy their standard stuff (eg. "Comfort Gas" or "Sports Gas" or whatever.
Personally though, I'd suggest KYB Excel-G shocks ... they are good quality & not overly expensive (about $100-$120 per corner, plus fitting if you don't know how to do it yourself).
The front strut inserts for LB/LC Lancer are the same as for GA->GD Galant and also GE Sigma. KYB Part No. 365004
According to the KYB online cattledog, rears for LB/LC are Part No. 343030
Posted: Mon Jun 18, 2012 10:22 am
by Leeroy
Yer its just ive been quoted ridiculous prices (gold coast) upwards of $600 for a pair of front shock absorbers installed.
I found these : http://www.gumtree.com.au/s-ad/gleneagl ... 1002560072
Are these the ones you were talking about?
Posted: Mon Jun 18, 2012 5:06 pm
by davetrees
Those are for a Hyundai ...... and will probably be a complete strut assembly rather than just an insert. (Many modern cars don't have replacable inserts). Same series of shocks though.
$600 to fit & supply ? That's over the top, depending on what sort of shocks they are !
Should be no more than a couple of hours labour max to fit them @ say $80-$100/hour ... plus the price of the shocks. Get another quote, broken down into parts & labour.
(Rear shocks you can fit yourself easy - should take about 15 mins max per side)
