got a few goodies for it already though..
interior..
me to ! what a great little track car can be made out of one , mind you I would look at building it to IPRA specastronturbo77 wrote:good stuff, wish i had a 2door
axle tramp would be the biggest thing to fix - but that can be doneBIG26L wrote:You have to do a lot of work to make the rearend work properly with that type of HP in IPRA.............
Distance between the rail and axle tube is the main drama, whilst trying bring the ride height down and keep some form of suspension travel.
It looks like its a better car to restore than turn into a racer...... That interior is almost untouched as from the factory.
or a set of tramp bars - and maybe stronger front half leaves , anything to stop the front of the leaves winding upBIG26L wrote:Axle tramp is fixed with a pair of upper arms facing rearward, so you don't cut into the floor and a set of decent adjustable shocks.
Panhard rod is a must do mod, as well.
yes it all helpsBIG26L wrote:Urethane or solid engine mounts fix a lot of that problem.......
