*4g54 bottem end(chrome molly rings & custom grind crank)
*magna shaved and ported head,low comp JP flat top pistons,custom grind solid camshaft 8:0 comp,ajusa steel gasket kit.
*TN magna injection with custom manifold(thanks to stealth performance)
*75mm billet thottle body (had to change that pissy little one)
*MICROTECH LT10S aftermarket ecu
*custom turbo manifold with T3 flange and dump pipe
*nissan T3 turbo(came out of a r34 skyline)
*2 1/2 exhaust system,hot dog,4"muffler and 3.5"dumpy
*excedy heavy duty clutch
*VR4 front mount intercooler 600x400 i think!(thanks to a member from here i dont remember his user name.but it was sumfin like vr4man of sumfin??thanks anyway)
*black powder coated cooler piping with t clamps
*hks turbo timer
*greddy profect s electronic boost controller (single stage turbosmart one instead)
*standard gsr diff wit 4:11 spool
*suspension (pedders shockers all around,king springs-superlow front and back,nolathene bushes all around
*surge tank(in boot)
*VL turbo fuel pump and bosch 440
*19 akita wheels??(MAYBE PUT THEM ON)
*autometer gauges on the bonnet x3(MAYBE PUT THEM ON)
thats as much as i can remember atm.the car is currently at home and im in the process of wiring up the microtech.i just painted my turbo manifol and waitn for the gaskets to arrive..im also still waiting on the cooler piping aswell.still got a bit to go but ill keep youz up to date??
