Next thing to deal with was the power windows switch.
First they started to fail on the main one (passanger window couldnt go up) and also letters worn out after years of using
First i have disassembled everything, cleaned up the contacts, and it all woreked again like a charm
Then i found a ultra rare JDM main power window switch that has Door Lock option on it and AUTO funstion for drivers window.
It was in Malaysia, and it is very very hard to communicate with them and in the end to get parts from
So i accepted a challenge of making a UNIQUE, only in the world, LHD main switch with AUTO power windows on drivers doors, and Door lock option
And finally received it after 2months
Next big problem was it was all for RHD (you cant put AUTO function on the left side) and also you need to use LHD plastic surround to fit properly
However plastic surround didnt have DOOR LOCKS sign
after days of researching, find up it wasnt a sticker on the buttons and plastic surround. It was printed with high quality colour that remains under usage of fingers
luckily i found one guy who was able to do this for me, so i have also refurbed buttons and plastic surround, also all other buttons on passanger doors
next thing about AUTO function. Mitsubishi Galant Sigma in USA had AUTO function on driver window as a LHD. luckily found one with broken plastic and cutted wires, but again seller didnt want to ship, so I had to find agents etc.
after 2more months finally item arrived
next problem was it didnt have DOOR LOCK, so i had to cut the JDM one and weld it with USA one
Next. all was working except AUTO function for driver window when it go UP.
Thing is, in the US there was a child proof law. so the button had some kind of restriction, and also 1wire was missing from the small control unit plate (white wire in the picture above was added).
When it all was solved , here is the final result
From 3very rare parts, I got 1 Unique with all functions working
Final result: astonishing
