1985 GK GSR Project
Re: 1985 GK GSR Project
Personally, I have 2 MOOKEEH Mk2 short shifters and they are great..
It was quite different to when I drove my Triton for the first time, getting used to the standard gearstick.
Just have to change the diff ratio from 5.1:1 to 3.9:1 to make it a bit more usable, along with a set of 17" rims...
Yeah there pretty good I reckon. Did u get urs of eBay 2?
I'm spewing I should of got mine ages ago when our dollar
Was heaps better than the U.S. but didn't have
Spare cash then.
I don't really understand diff or compression ratios
They both go over my head haha
Just out of interest how do the bigger rims help?
Thanks
Spare cash then.
Thanks
85GK GSR - EFI Camn
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1000270-1.jpg)
85AB GSR VR4dia- Build
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1010674-1.jpg)
I think you are south of Adelaide yeah?A112H wrote:I have a tank and facet pump I won't be using if you are interested? $80 the pair.
I will be out and about in the hardtop tomorrow so might be able to do a hand over
Oh ok what area will u be? What's ur number ? $80 yeah?
And u said has instructions doesn't it? Thanks
85GK GSR - EFI Camn
ended up getting the surge tank, and fuel pump off A112H, and lots of fittings etc. Thanks again
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060336.jpg)
this is my boot at the moment lol
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060302.jpg)
where im thinking of mounting it
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060330.jpg)
this set up at the moment
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060332.jpg)
goes through Z153 filter then into the pump
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060310.jpg)
anyone know what pump this is? no number on it what so ever and quite smaller than the bosch
is it the standard magna one?
this is the one got with the surge tank
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060341.jpg)
Bosch 0 580 254 910 rated 130psi per hour,10A current
have no idea what the other one is rated at, no markings on it.
Is too much pressure bad? and will the z153 fuel filter b upto it also? bearing in mind running standard tr magna set up at the moment.
also yesterday got some extra fitting + hose, cos the fittings on top of fuel tank are all 6mm
apart from one 8mm one, got 8mm hose hopefully can get it tight enough on the 6mm tank fittings
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060340.jpg)
also have noticed when they did my efi conversion. in the sigma manual looks like the 8mm pipe is
the return hose, which they are using as the supply hose, will this cause problems? suppose there both going to tank though
guess they wanted to use the bigger line.
85GK GSR - EFI Camn
and just looked on the bosch website the output of the pump
are were the voltage terminals are, so think the pump is round the wrong way?
better swap that over before i forget lol.
85GK GSR - EFI Camn
Hey all. Just wondering if anyone knows the standard
Cam duration for a tr magna 4G54, and the power range.
Tried googling it but not having much luck finding
The info I need. Thanks
85GK GSR - EFI Camn
went to wreckers today was after something for other cars
but came across mint TR Magna rocker cover.
thought i d grab it, wont take much prep to paint up cos is fairly clean
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060789.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060788.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060792.jpg)
and spent a bit on paint
primer, anodized red (to match the oil cap hopefully), and a gloss clear coat
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060773.jpg)
also my haltech was missing the sensors :/... air temp and map sensor so grabbed some them of another car
hopefully have some sparetime to install it soon.
and hopefully some nice sunny weekend to do the rocker cover too, which is a bit hard this time
of year.
of year.
85GK GSR - EFI Camn
got stuck into the rocker cover today
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060802.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060810.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060813.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060817.jpg)
Only got one coat of primer on before it started rain always rains when i try and paint lol :/
got few runs too, out of practice lol, back to sanding lol![sad :(](./images/smilies/msn_sad.gif)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060829.jpg)
85GK GSR - EFI Camn
today got new rocker cover gasket set, and some gasket maker
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1060950.jpg)
whacked another primer coat on today
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070050.jpg)
with weather looking ok tomoz, hopefully can get sme red on it finally
85GK GSR - EFI Camn
another lot of primer
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070055.jpg)
first coat
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070065.jpg)
2nd coat
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070086.jpg)
after all that dunno if like the colour :/ too much of a half a**ed red, a redder red wouldve been better![sad :(](./images/smilies/msn_sad.gif)
first coat
2nd coat
85GK GSR - EFI Camn
looks more bronze. Depends what colour everything else is gonna be. I done mine orange.
![Image](http://i49.tinypic.com/2niwvwg.jpg)
Just a dumb question....but what gear box are you running????
is it a wide or narrow block??
Nice lookin engine man, very tidy what turbz u running looks bigSIC082 wrote:looks more bronze. Depends what colour everything else is gonna be. I done mine orange.
85GK GSR - EFI Camn
back in 2009 when did the brakes, noticed the rear rotor was nearly at max tolerance
so ordered some new slotted rotors for the rear, plus the hand brake don't work to well only on last click
so maybe the inner drum part is quite worn too. hopefully this will help if not looks like need new shoes for the handbrake part.
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070421.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070420.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070424.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070425.jpg)
only prob is different slot type to what i put on the front
think the fronts were protex for memory, not dba
i hate things that dont match. oh well least you cant see the brakes with the standard rims :/
none the less pretty sexc brakes IMO
Thought id at least finish the brakes, till work out where next for the engine.
85GK GSR - EFI Camn
- TUFSIG
i will need to do the brakes on TUFSIG with the turbo on it now ![tongue :P](./images/smilies/msn_tongue.gif)
are these made to fit sigma ? direct bolt on ?
TUFSIG
Boost Is the Only Way
1984 GK Sigma GSR Stocka
![Image](http://i91.photobucket.com/albums/k318/Kingpin_05/TUFSIGbanner1.jpg)
Yeah spose to be direct bolt on, I think will check
On weekend if fits. Part no dba207s. Had to wait few
Weeks so they prob had to make em up. Were round $150 ea
Centre is painted black, looked in there brochure can get
The centers painted gold also I think. And apparently
Can get ones that have thermo things that change
Colour at diff temp hehe.
Some dudes gsr was looking at. that had vr4 in it was running some kind
Of Volvo brakes. Guess the standards weren't good enough to stop it.
Was a moded vr4 engine I think. But ur prob still making more kw than it.
wish I knew what Volvo though, I'd assume would be
A bolt on upgrade but don't know for sure. Wish it was as easy as a cordia
Vr4 twin pot calipers bolt straight on to them. Those calipers stop good.
85GK GSR - EFI Camn
Dunno if this helps http://www.network54.com/Forum/133789/t ... der+%24150
I might go to wreckers and play with Volvo brakes
And see if they fit a gk haha
85GK GSR - EFI Camn
they actually had an 84 GK GSR, spoiler gone already , most panels on it were fair rusty in panels
grabbed the front bit above the front grille.
but did find a GN with decent passenger gaurd, well straight atleast
and grabbed some front bits from that too
just need to find straight bumper, then its time to get them painted and matched to the rest of the car
to make the car look decent again.
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070448.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070451.jpg)
85GK GSR - EFI Camn
haven't done alot lately, been spending time with the other car alot more
but since wasn't raining today, decided to put the new dba t2 slotted rotors on the rear
Started with passenger side
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070725.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070729.jpg)
removed the old rotor (bit scored)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070730.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070733.jpg)
cleaned the rust of the hub
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070762.jpg)
old rotor measured approx 9mm think the min is 8.8mm, so not far of being shagged
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070754.jpg)
new one is approx 10.5mm
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070775.jpg)
put the new disc on and caliper back on(thought I'd take a nice pic of it before it goes rusty)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070787.jpg)
then did the other side
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070839.jpg)
brakes feel a lot better now, even at idle when i have no brake booster cos of the rough cam
but unfortunately the handbrake is still no good
dunno if i need new shoes maybe??
measures bout 6mm including the metal part of the shoe
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070804.jpg)
but bout 3mm of that is pad
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1070808.jpg)
anyone know the minimum tolerance for the handbrake shoes?thanks
85GK GSR - EFI Camn
lovin this build man keep up the good work
james
james
Thanks man, still got fair bit to do, and gotta fix up the front end
Prob put the surge tank in next. Then when
Finished other car hopefully squeeze a bit more
Out the engine.
Out the engine.
85GK GSR - EFI Camn
- TUFSIG
needs more turbo ![tongue :P](./images/smilies/msn_tongue.gif)
TUFSIG
should be enough pad, just need to adjust the handbrake, there should be a little wheel with teeth on it you can turn to adjust hope that helps
![Image](http://cdn.uproxx.com/wp-content/uploads/2011/09/alwaysunny-crash.gif)
Gregory's manual has all the "one time specs needed" u'll ever need lol
It so does haha, dunno if can afford 2 turbo carsTUFSIG wrote:needs more turbo
But be rad though
85GK GSR - EFI Camn
Awesome thanksSigmoe wrote:should be enough pad, just need to adjust the handbrake, there should be a little wheel with teeth on it you can turn to adjust hope that helps
85GK GSR - EFI Camn
Old faithful gregoresScorpma82 wrote:Gregory's manual has all the "one time specs needed" u'll ever need lol
Got for gh, better get one for gk lol
85GK GSR - EFI Camn
So with the other car I've been working on
Been having probs with idle. I suspected
The isc motor on bottom of throttle body.
I compared it with the sigs tr efi setup and
Looks the same from outside. But when I metered
The sigs one to compare it with the other car's one. found one coil was open.
so pulled the old faulty one out
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080595.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080596.jpg)
cleaned the hole out a bit
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080614.jpg)
cleaned up the one from wreckers
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080577.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080581.jpg)
whacked it in
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080617.jpg)
Few others I measured at wreckers we're open on one coil also
Must be a common prob. Oh well hope it fixes
A few of my idle issues on the sig.
whacked it in
85GK GSR - EFI Camn
finally found some spare time to put the rocker cover on today
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080728_zpsf69aed10.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080733_zps02fa8208.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080745_zps867a4246.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080756_zpsace9dd17.jpg)
![Image](http://i240.photobucket.com/albums/ff230/metalcoremarc/P1080753_zpsf1033276.jpg)
prob should do my extractors done too. or get em ceramic coated.
and lose the big ugly afm and put the haltech in soon hopefully
was gonna have ago at adjusting the handbrake but broke a shock in my other car so gotta fix that asap![sad :(](./images/smilies/msn_sad.gif)
85GK GSR - EFI Camn
