Triton magna EFI build
OK So
i have a 96 triton with 422 thousand on the clock original motor and she is very low on compression and just started making the lovely sound of a big end knock.
so for a temporary fix going to put another half life motor in it till i biuld the EFI Motor
i have a new m7 head so thats sorted just need a fresh bottom end to bolt to
im going to try to reuse the triton block if i can or i have another astron 1 block around here with clean numbers
im going to purchase a doner magna and swap everything over it will be stock as a rock no fancy turbos just as i was from factory.
i want know
- if i put in a set on new pistons can i reuse rods and pins?
- can i use any crank magna triton or siggy?
- do i buy new standard rod bolts main bolts etc or can i reuse?
- should i use magna or triton pistons?
- do i need a lift pump and surge tank can i put in a intank pump?
- do need to get a motor builder to check over the block or is it fairly straight forward to do myself?
- should i get it profesionally honed or can home jobs be just as affective?
more questions will come when i run into them
ill keep a track with photos ect.
i want know
"Boosted is The Only Way To Live"
<Sigma Turbo No.177 >
<96 Astron Powered Triton>
<81 GJ Scorpion>
<81 GJ Scorpion>
Re: Triton magna EFI build
-when you buy pistons thay will supply pins and reuse rods after getting
them close and honed
-yes any crank will do
-get arp rod bolts there cheap insurance
-magna pistons are flat tops (not all so get the right ones
-no you dont need a surge tank intank pump will do
-and yes get it honed professionally or risk blow by
and are you still chasing a manifold rwd conversion done?
cheers stealth
cheers stealth
sweet great info
still keen on the cut and shut ill let you know when i pick up a magna
one i thought of on the way home can you use the magna fuel pump?
how necessary are the O2 sensor i remember reading a story about the conversion and not using one?
still more will come ill put up a few pics tommorow.
<81 GJ Scorpion>
<81 GJ Scorpion>
ok got the half life motor in this weekend all good until spanner dropped into fan while running and epic fail busted radiator smashed fan not happy
so i spend my monday looking for radiators instead of working.
once i get the old motor cleaned up and on the stand work will begin.
some pics of old engine before removal
click for closer look
cheers.
cheers.
<81 GJ Scorpion>
<81 GJ Scorpion>
- TUFSIG
great work mate keep it up
TUFSIG
Boost Is the Only Way
1984 GK Sigma GSR Stocka
got a new radiator massive dent in the budget for that one but it was repair the old one which was shagged anyway and have no garentee or bite the bullet and go new.
the interim motor is in and working got back from northern nsw to brissy a ok needs a tune and what not.
now the old engine is home tommorow ill wash it and start dismantling.
<81 GJ Scorpion>
<81 GJ Scorpion>
- TUFSIG
let the fun begin
TUFSIG
few pics to keep me motivated
got every thing to bits found a good thing exedy HD clutch still lots of meat on it
and a few of the engine
notice the oily carbon on the pistons cant think there much of the rings left
much more to do but ill have to wait till the silly season is over and workshops open again.
can anyone advise on engine builders in brisbane area???
<81 GJ Scorpion>
<81 GJ Scorpion>
Project on hold
going to focus on turbo
<81 GJ Scorpion>
<81 GJ Scorpion>
It is Finally done Triton running on EFI with a few gremlins but looks awsome
specs aint exciting
-crack tested block all checked over and cleaned
- linished crank
- new pistons to fit 1mm overbore
-original rods
- new bearings rings ect
-brass welch plugs allround
-late model magna head new valves double valve springs
-TR injection and standard computer
-extractors to standard exhuast.
-standard fuel pump and tank from MK triton 97-06 bolts in the same no mods
few tips i found
have your fuel rail shortened by 10mm or massage the firewall with a hammer before the engine goes in.
if you confident re-loom the wiring harness unds up far neater
get the magna manual from the post on here print out the bits ya need ie electrical fuel ect comes in handy only cost $20 at officeworks.
get a whole magna and take the bits off saves you trips to the wrecker for little bits here and there.
test and check ever component from the doner car im having issues now becouse i didnt my doner barely ran when i picked it up.
specs aint exciting
- linished crank
-original rods
few tips i found
<81 GJ Scorpion>
<81 GJ Scorpion>
[quote="sigtool"]
Did you use the fuel tank from a 2.4 mk triton? have ya had any trouble with fuel or anything? im gathering all the bits and pieces to convert my triton to efi and was going to do the whole surge tank and pumps option until i saw your posts!! sounds like an easier option
hey mate
im guessing you sorted al this out by now
but installed a MK triton fuel tank from the 2.4 EFI fits same mountings no drilling at all.
<81 GJ Scorpion>
<81 GJ Scorpion>
well done mate .
Bring her around i want to take a look...
love to mate but the old truck is a nsw resident with my old man these days didnt need it got a company car.
but once i get my new scorpion on the road i will let you know we can catch up
<81 GJ Scorpion>
<81 GJ Scorpion>
,,,I think thats..very kind of you reco ing the engine , converting it to efi and then giving it to your father.
