little hulk
Re: little hulk
Are you absolutely sure that you need a booster to be legal?
Mine hasn't got one (for the same space restrictions) and the Engineer had no problem with it at all.
Was registered in Vic and simply changed over now into QLD reg.
I'm used to it now so you just push the pedal harder![teeth 8o|](./images/smilies/msn_bareteeth.gif)
Re: little hulk
Yup , if it had one factory it has to have one , anything 1976 onwards
Unless you do the ADR test to have it certified
All you need is one cop to actually know what there talking about and your defected
But I wouldn't worry about them its QLD transport utes cruising around , those guys do know all the rules and will do you in a heartbeat
Cheers stealth
Cheers stealth
Re: little hulk
The Engineer did all the brake testing required. x number of .5g stops etc.... without fade all logged with a computer.
So hopefully no problem![tongue :P](./images/smilies/msn_tongue.gif)
Re: little hulk
So I got the x member powder coated over the weekend
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_104427_zpsra1impxr.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_104414_zpswq9a0yzj.jpg)
So that got me motivated
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_142235_zps2bxetbgl.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_142357_zpsd8ufqtbr.jpg)
And that gets the length or pipe to what the computer recommended at 680mm
Now 5 more pipe and then collectors , to easy
Cheers stealth
Cheers stealth
Re: little hulk
So im chasing a gasket kit for the engine rebuild
Can anyone help ? I cant seem to find one apparently it doesn't exist !!
Anyone please
Cheers stealth
Anyone please
Cheers stealth
Re: little hulk
What engine again??
Re: little hulk
6g73 Dohc twin turbo, out of a 1995 Vr4 galant
Cheers stealth
Cheers stealth
Re: little hulk
I gotta disagree, I know off 2 cars 3 if you include the one we stripped that have or were a factory 6g73
Either way all I need is a gasket kits
It shouldn't be that hard ,
Cheers stealth
![facepalm :facepalm:](./images/smilies/facepalm.gif)
Cheers stealth
- amgis_obrut
Re: little hulk
Yes looking into the gaskets it seems the 6g73 was only available in naturally aspirated form, the only TT 6g7x series engine I can find is the 6g72
Re: little hulk
Na gaskets will do !
Theres fuck all differance ,8.2 or 9.0 to one
But how confusing , im told today that 6a13 gaskets should fit , but gotta buy em to find out , so 450 pounds later plus freight to find out
Hmmmm
Cheers stealth
Hmmmm
Cheers stealth
- amgis_obrut
Re: little hulk
theres heaps of 6g73 gasket sets with head bolts on ebay US for about $130usd, DOHC sets seem hard to find though im not familiar with the engine and don't really know whet im looking at
- amgis_obrut
Re: little hulk
would a 6g72 set fit ?
http://www.ebay.com/itm/Dodge-Stealth-3 ... e1&vxp=mtr
http://www.ebay.com/itm/91-99-Mitsubish ... 03&vxp=mtr
Re: little hulk
Will find out, just bought it
Thanks mick
Much appreciated
Cheers stealth
Thanks mick
Much appreciated
Cheers stealth
- amgis_obrut
Re: little hulk
Even if the gaskets don't fit (im sure most will), its still a cheap set of head bolts and valves
Bit of luck the 72 valves are bigger than the 73 !
Re: little hulk
Lets hope it fits!!!
PS Still not to late for a 700hp 4g64 build sequential twin setup.![tongue :P](./images/smilies/msn_tongue.gif)
Re: little hulk
Again thanks mick
And jimmy , its never to late , when I finish hulk im gunna do my la coupe /2dr
With my full house 4g63 ,out of my world time attack car , it made 1082 at the treads
And its no dyno pony , and ps you do need a 64 crank to make hp , and the 63 makes power to 8000rpm
Cheers stealth
Cheers stealth
Re: little hulk
Couldn't help myself
Just bought , Arp stud kit , set of cp forgies, h beam rods and some 292 ,10.5 lift crower billet cams
So at least the inturnals should be up for a bit of booost
Cheers stealth
Re: little hulk
Sorry been busy as
Some rods and stud kit arrived still waiting on cams and gaskets
Im still flat out for another two weeks then hopefully I can get back into it
Cheers stealth
Cheers stealth
Re: little hulk
Finally got some work done last night
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_150922_zpsrdxpvtuu.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_150931_zpsier2e5sk.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_153623_zpspoob21qp.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20150825_153732_zpsnniauler.jpg)
Less and less room , the second pipe on the passenger side "no. 4" cyl , same thing again just gotta make it fit
Cheers stealth
Cheers stealth
Re: little hulk
Re: little hulk
So did some more today
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151027_115820_zpsgfioazst.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151027_144805_zpsedh7aqlp.jpg)
And as I have been working I have now noticed the next major issue , the clutch slave cylinder fouls on the steering and I need to relocate the mounts
So looks like cut the mount of the bellhousing and relocate it 10mm back and rotate the bolts about 30 degrees , so soon as pipes are done there's another job to put on the list
Cheers stealth
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151027_145043_zpssmkiobl0.jpg)
Cheers stealth
Re: little hulk
So another few hours , I skipped ahead a bit
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151027_145139_zps876sxeig.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151027_150011_zpsahveokzv.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151108_125916_zpsn5dmjyam.jpg)
So bit of welding to do and then the collector and the other side
But I think its coming along nicely, nothing fancy
Cheers stealth
Cheers stealth
Re: little hulk
So fill me in if I were to put a 3.5 Pajer engine what 2wd manual g box would mate up to it? Or is it a custom bell housing
Re: little hulk
Another half a day
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151108_195039_zpsjmquwhtq.jpg)
![Image](http://i358.photobucket.com/albums/oo27/samandotto/Mobile%20Uploads/20151108_195119_zpsdfkubnqv.jpg)
So now the collector , then the other side , I will buy more bends this arvo and do some more , turning out to quite a large amount of work , im loving it
Cheers stealth
Cheers stealth
Re: little hulk
Could u stuff the internals of a starion/jap sigma box into the casing of a triton box?stealth wrote:Well I have options for the gearbox ...
So the winner is a triton gearbox , im going to try how it goes as its super close ratio and huge
Cheers stealth
It would solve ur ratio problems
Re: little hulk
The v6 triton box is a different gearbox to a km , seriously bigger , I will take pics next time its on the floor
Cheers stealth
Cheers stealth
