After years of the turbo 2.6L / W55 supra combo I have decided to do another engine swap on the car. Since the drag racing scene is back in adelaide im converting the GJ into a drag car. Not full blown with a shoot but half way between street car and drag car. Its been a while since ive posted on here as its been a big pain in the ass to get a TH350 trans to fit. Photos will explain...
Managed to pick up a 4G63 that was in a VR4. Was stroked to 2.4L, balance shafs removed, forged pistions, H beam rods, ARP bolts, Oversised valves, doubble valve springs, tititanium retainers. Was pulling 193Kw at all wheels with standard cams and bigger injectors. Guy had it in his car for 6 months, did 8 thousand ks on it and bent the car in the hills, so got it for a good price.
Bought a set of Kelford 280 Degree cams with 11mm lift... Hanging to get this thing going!!
Car with the new heart next to it ready for the removal...
ready to go.
Bought one of bills adaptor kits...
managed to get my hands on a cheap Autronic SM4 with CDI box
Went all out on a new TCI TH350 rated for 700HP with trans brake... No mucking around here...
Went and bought a Hurst Pistol grip shifter to suit
Got a Conver made 4500 stall, like i said not doing things by 1/2 here. Fitted the engine and trans together and went to fit it in the car... Trans hits the tunnel... Swear i read somewhere that they fit, but no way this was gonna clear. Out with old mate angle grinder and this is the result...
And then as a result a new tunnel needed to be made...
painted
Had to make a trans mount. Had a good friend come over and give me a hand with the mount and had worked for SA chassis service a few years back and highly recommed me to cap the rails and seam weld the rails in the engine bay to prevent twist...
Trans mount
1.6MM Cold rolled steel that i bent up to follow the form of the rails under the car
plugged welded rails under the car...
welded rails in the engine bay, and as a result i decided to pull everything out and paint the bay again. (been 9 years since i did it)
went for the Jet back engine bay this time...
Suspension and steering back in.
Will be getting around to finishing the tidy up of the rail welding under the car tomorrow and some of the wiring to the front of the car... More phots to come...
