![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
Slotted discs
Slotted discs
DBA do slotted discs for just about all the old Mitsis ![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
- DanTurboLancer
Re: Slotted discs
Good to know, thanks Lean!!
- Rally_2.6LC
Re: Slotted discs
Slotted yes but alas no off the shelf vented upgrade....gotta go Starion
Cheers Matt
Cheers Matt
Re: Slotted discs
I got mine from ebay for about $79 I think, can't remember. Part # RDA205S
![Image](http://i234.photobucket.com/albums/ee271/Galant_GTO/brakes3.jpg)
- DanTurboLancer
Re: Slotted discs
Can the Starion Disks be used on the Sigma Stub Axle using different bearings?
Or do you mean Starion Struts have to be used also?
Re: Slotted discs
Starion brake callipers wont bolt to the Sigma struts, so you'll need the Starion strut + hub + rotor + calliper. You need the Sigma strut top, and the Starion uses the same front springs as the Sigma. Unfortunately, DBA don't make the DBA400 rotor, which is for the Starion front. RDA do, there is some on eBay, but still not that available.DanTurboLancer wrote:Can the Starion Disks be used on the Sigma Stub Axle using different bearings?
- DanTurboLancer
Re: Slotted discs
Thanks Cottees,
I was wanting to see if I can use the Starion Disk on the Sigma Strut/Stub Axles,
By just useing different bearings inner and outer o make it work??
I will make an adaptor to suit the Calipers as required
Re: Slotted discs
Just had another look at the front bearing kit for the Starion and Sigma, and both are GBC GBK0214. If you want to make custom parts, you might want to look at more common rotors and callipers.
Re: Slotted discs
These are the bearings from a Starion hub :
![Image](http://i620.photobucket.com/albums/tt288/Cottees/Sigma/IMG_0088.jpg)
![Image](http://i620.photobucket.com/albums/tt288/Cottees/Sigma/IMG_0089.jpg)
The reference numbers on them are LM67048 and LM11949.
A quick search on those part numbers sent me here :
http://www.toymods.org.au/forums/showthread.php?t=1944
Looks like the 4 stud Supras and Coronas use the same bearings. As well as others too.
