Centura Struts
- amgis_obrut
Centura Struts
anyone tried putting these in a sigma ?
if not im gonna have a go tomorrow
- DanTurboLancer
Re: Centura Struts
Interesting Choice
Do they look as though they will bolt straight in?
If not, then why?
Im all for trying something different, but they arent common anymore, and old as hell.
If not, then why?
Re: Centura Struts
they are the same age as an average lancer or galant. but yes interesting choice, my bro has two centuras, and they go hard bu thats about all.......lets say not renowned for cornering ![Laughing :lol:](./images/smilies/icon_lol.gif)
- amgis_obrut
Re: Centura Struts
i think if i change the tops and fit a GE balljoint they might work
reason im thinking bout these is i need a vented disc and uprated strut/spring for when i fit a 302 and a hemi centura front end would be about the same weight as a clevo gh front end, plus they have ford pcd
Re: Centura Struts
Centura/Commodore/Camira
Skyline /Pintara drop stright in, perfect fit to top mount , 40mm shorter body + 30mm shorter piston stroke![thump :thumpsup:](./images/smilies/thumbsup.gif)
![blah :blah:](./images/smilies/blah.gif)
- ralliartsigma
Re: Centura Struts
Hey,
Yep ive seen it done a few years back on a GH sedan with a 302 Windsor conversion, had a shortened ford 9 inch in the back and the guy put the Centura struts in so he could run a Falcon 5 stud pattern and discs all round (he had XR6 rims fitted). He had an early Fairlane as a donor car and was going to a V8 conversion to a Cortina but couldnt find a good one or could only find a wagon something like that...
Sorry i cant give you too many details or even photos but it was about 8-9 years ago and ive killed numerous brain cells since then, i remember it been a very tidy setup and having a half a chubby for about a month over seeing a V8 sigma (i was 17 at the time).
Cheers Trent
Cheers Trent
'83 GJ Wagon my baby, but sadly not driven enough.
'94 MJ Triton my daily in the colder months.
'81 GH Turbo No. 105 (WIP)
'81 GH Turbo No. 017
- amgis_obrut
Re: Centura Struts
but wont be valved for the extra weightSigmaproject wrote:Centura/Commodore/Camira![]()
- DanTurboLancer
Re: Centura Struts
ahh well that is a valid point, the Centura didnt come out with an 8
- amgis_obrut
Re: Centura Struts
yes but a cleveland is only 35kg more than a 245
a sigma with a cleveland would almost have the same front end weight and a 245 centura
My engineer wants me to fit a strut insert /spring combo that will be suited to the front end weight of the car, i could easily go and get something made but if anything every craps out i'd need to get it made again
If i use something oem i can just replace it with oem
Re: Centura Struts
Wouldn't using Commodore inserts and heavy duty springs in the stock stuts have the effect your engineer wants?
Re: Centura Struts
Then the engineer would probably need to do calculations to determine if the stub axles & bearings are suited to the load - which would cost bulk money.
If the OP can demonstrate that he's using front end components designed for a similar load it's simpler for the engineer to sign off, and cheaper for the OP.
(Formerly) 1984 GK SE Wagon
Kings, Konis, EFI, exhaust. Not much power.
But it is red!
And Sold...
Member's Rides Thread
- amgis_obrut
Re: Centura Struts
Galant_GT0 wrote:Wouldn't using Commodore inserts and heavy duty springs in the stock stuts have the effect your engineer wants?
thats another option
Commo inserts would be valved right, i could use these with off the shelf centura springs all on the sigma struts and meet the engineers requests, and then i could use the front brakes of my cortina (changing to Strange set up) and have the vented discs with ford 5x114.3 pcd
OR i could just use the entire Centura strut and brakes and be done with it in one move
I'll be starting on the front once i have finished the 5 stud lsd diff conversion
- amgis_obrut
Re: Centura Struts
started stuffing about with these centura struts today
Well the complete strut/brake setup wont fit a sigma with out major work, the disc will fit the sigma strut but needs a rear bearing spacer, discs are impossible to get making the conversion a no go
So i abandoned the idea of fitting the complete strut or the brakes and started looking at other routes
The Centura strut insert is a drop in for a Sigma strut, the insert body is the same length but the ram is 30mm shorter (good if you have shorter springs)
So im going to use the centura inserts springs and top spring plates on the sigma struts
![Image](http://i796.photobucket.com/albums/yy248/Gassed250_album/SAM_0290.jpg?t=1272205090)
- amgis_obrut
Re: Centura Struts
I have given you lot a bit of a bum steer with my last post as the sigma insert is from a GJ not a GH
the GH insert has a longer body than the GJ though both will interchange if you use the correct retaining nut
I used the Centura insert in the GH strut and the GJ retaining nut for a perfect fit without the need for spacers
Ok top to bottom, GH Sigma, KB Centura, GJ sigma
![Image](http://i796.photobucket.com/albums/yy248/Gassed250_album/SAM_0293.jpg?t=1272259876)
GJ retaining nut on left vs GH retaining nut
![Image](http://i796.photobucket.com/albums/yy248/Gassed250_album/SAM_0294.jpg?t=1272260264)
Springs, left to right
KB Centura, GH SE, GH Turbo
![Image](http://i796.photobucket.com/albums/yy248/Gassed250_album/SAM_0291.jpg?t=1272260821)
And this is the strut brake combo that im using for my clevo conversion, its a real hybrid and was a dead set head frak to sort out
it consists of
STRUTS>
GH Strut
Centura Insert
GJ retaining nut
Centura spring
Centura top spring plate
GH strut top
BRAKES
XA falcon hub/disc
HQ Wheel bearings
WB Caliper
Falcon hoses, have now been swapped for rear disc sigma hoses
TE Cortina to Holden caliper mount, you can either get these from CRS or just make them from some 10mm plate
![Image](http://i796.photobucket.com/albums/yy248/Gassed250_album/SAM_0297.jpg?t=1272261236)
it consists of
STRUTS>
GH Strut
Centura Insert
GJ retaining nut
Centura spring
GH strut top
BRAKES
XA falcon hub/disc
HQ Wheel bearings
WB Caliper
Re: Centura Struts
wayyyy too confusing for me haha
top work
top work
- amgis_obrut
Re: Centura Struts
dunno what it'll handle like, but yeah its mainly for the weightvr4retrofit wrote:Love your work![]()
Will this handle any better or is it just to take the weight?
Sorry if thats a dumb question but I know bugger all about suspension.
Re: Centura Struts
Very interesting thread - nice to see someone experimenting.
My guess is that it will sit too high, and have a stiff ride, but I hope I'm wrong
(not really being a Sigma chap)
T.
T.
John Ruskin
John Ruskin
- amgis_obrut
Re: Centura Struts
Its not much stiffer than the std setup, Overall strut height is 40mm shorter now, but still sits higher that the std sigma setup but should come down with the weight of a Cleveland,
- DanTurboLancer
Re: Centura Struts
Good on you Mick!
hope it works for you.
Wasnt the point to go 5 stud also?
And now you have stripped all your stuff out of the Corty??
Or was the Corty always getting new gear?
- amgis_obrut
Re: Centura Struts
Yeah 5 stud was the main thing, it will all work
have only pulled the front brakes off the Cortina, didnt like them that much anyway, to bulky and heavy goingf to fit some custom alloy hubs light weight 8mm thick discs and strange calipers save about 50% weight over the old setup
- amgis_obrut
Re: Centura Struts
front brakes are 905 finished just need to find some hoses
Sits a little high now but we can fix that with cubes lol
![Image](http://i796.photobucket.com/albums/yy248/Gassed250_album/SAM_0301.jpg?t=1272450112)
![Image](http://i796.photobucket.com/albums/yy248/Gassed250_album/SAM_0303.jpg?t=1272450389)
- amgis_obrut
Re: Centura Struts
Cheers mate
Engine wont be in for a few weeks need to do a few things to it first
Re: Centura Struts
looking good bro
u have to take me for a spin when ya get it all sorted out
