commodore brake conversion GD coupe
astronturbo77
Post by astronturbo77 »
hi guys, i have been wondering aout doing a commodore brake conversion using gh sigma struts. a while back i was chatting to a bloke with a hemi pwrd sigma, He was saying that comodore VR/VS? disc rotors go onto sigma struts as the wheel bearings are the same and then you have to slot one hole in the caliper bracket for it to bolt on. I wish i could remember what model commodore he was talking about, it is the one with out the slip off disc rotors, either VN or VR. Can anyone help me with this is it correst or not? I can get VS discs and calipers for nothing but im unsure if the discs have the wheel bearing as part of them or not? and are they single piston calipers?
VT commy calipers are dual piston, is there any way of using these with VS discs?
wheelnut
Re: commodore brake conversion GD coupe
Post by wheelnut »
havnt seen it done but the vs rotors dont have a wheelbearing its seperate and vt calipers cant be used with vs rotors as they are too thin but vt rotors go onto vs hubs.most of the early rotors are the same except for bt1 and some vp-vr's
gb galant efi 2.6 track toy
gj sedan hack car
stealth
Post by stealth »
mate you can buy the kit that just bolts them straight on
that would be the easy way and already engineered with papers
cheers stealth 8-)
COBWBS
Post by COBWBS »
i did it...
Was easy as
Formerly known as QIKSIG
77 Lancer
astronturbo77
COBWBS: you mean with VN/p rotors and what about the caliper brackets? if you can get me some more info that would be good. :D
camB
Post by camB »
Hi there. I have a GE Sigma/Galant which came with 13" rims and those piddly square pads and single spot calipers. I ripped the struts (discs, calipers, stub axles, bearings attached) out of a GH and swapped them straight in. It moves me up to those C shaped pads of the early Commodores. Hope that's useful.
COBWBS
Post by COBWBS »
astronturbo77 wrote:COBWBS: you mean with VN/p rotors and what about the caliper brackets? if you can get me some more info that would be good. :D
Buy GH struts, Strip them
THEN
Ring these guys. www.hoppers.com.au
Tell them wat u want, Get there bank details,
Put money in ACC
and BANG!! a indian man arrived at your door with a box..
U open the box and inside is a set of 300mm Brakes with DBA slotted and x-drilled brakes.
with Series 3 AU Calipers.
Bolts all up and within 2 hours your driving with HUGE brakes.
I got holden Pattern 5 stud.
Cost about 1400 bux.
Nothin else to it
Scott
77 Lancer
boyracer
Post by boyracer »
I hope he knows he is up for bigger wheels and rubbers. I'll stick with my 13 inches.
3x la lancer 2door
2x gc galant hardtop
1x gc galant wagon
S1GMARE
Post by S1GMARE »
boyracer wrote:.
Isn't it obvious? If your using commo brakes/studs you would need the GM rims anyway.
I'd rather put drums on the front of my car than run big discs. Wheels bigger than 14"s is just showing off, and ugly.
COBWBS
Post by COBWBS »
Im running 15+4 inch crappadoor interceptors..
Im putting drums on the back as i herd u can get ones that self adjust for less maintenance coz my trolly jack is broken and im borrowing my next door neighbours and might not get it again this month..
77 Lancer
