I got the idea from another member.
But i have taken the photos as i have gone so i thought i would post it and it may help others.
Basically i have some struts out of the GJ-GH Sigma
My aim was to try to fit a disk and caliper package that was a straight bolt on unit.
However after asking the questions, and going to wreckers and brake parts suppliers had had any luck.
then another member showed me his setup, and while is not a direct bolt up situation,
It does require some basic machine work.
It is very cheap!
And so the minimal costs involved if you had to get a shop to machine them for you would be bugger all.
Perfect for Rally cars, And Circuit Cars.
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0964.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0968-1.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image1022.jpg)
The best part is, The Mounting surface is exactly the same distance from the strut with the new Hub and disk, as the standard Sigma.
So it doesnt upset the wheel track!
Sigma
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image1163.jpg)
New Hub and Falcon Disk
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image1167.jpg)
Many may know that the GJ-GH Sigma strut has a Stub axle with Bearing ID (Inside Diameter) surface on the Inner Bearing (Nearest the Shock) of 31.7mm,
and the outer Bearing mount surface Diameter is 19mm.
Which means it shares the same Stub axle diameters as the Holden Commadore.
So i went to my local Camping and trailer shop,
and looked at their selection of Trailer hubs.
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0621.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0622.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0626.jpg)
The choices you have here are a Ford 5 stud pattern, and you can have it with either Holden, or Ford wheel bearings.
or a Holden 5 stud pattern, and again either Holden or Ford wheels bearings.
But as i said the Sigma struts I am using have are a straight swap to Holden bearings.
I originally brought the Holden stud pattern hubs, (for ease of finding wheels)
then went straight to a Brake supplier, only to find that the hub wouldnt go straight into the inside of the Commadore disk,
and so i would have to machine the Outside diameter of the hub down, and i was worried about weakening the strength of the Hub and wheel studs if i took too much meat off, and machined too close to the studs the steel might crack.
So I ended up with the Ford 5 stud pattern and Commadore bearings - Around $35 each with Bearings.
Now bare in mind, that because I have choosen to use the Ford stud pattern as it means little other changes to the hubs themselves,
and strength by using 5 instead of 4 studs,
you could just as easily get a machine shop to knock the 5 studs out, fill in the holes, and redrill to suit whatever stud pattern you like,
just make sure you will be able to buy a floating brake disk to suit your stud pattern.
4 X 100 would be easy, im not sure about 4 X 114.3??
I cleaned up the Sigma strut and stub axle,
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/IMG00159-20100814-1113.jpg)
Slid the Holden Inner wheel bearing on then rested the Hub over the bearing.
Even with the Air guide sheild still on and standard Caliper Bracket, the Hub does not foul on any part!
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0634.jpg)
However the Outer bearing sat too far out and wasnt seated on the stub axle properly, it was hanging out onto the thread too far.
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0639.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0580.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0585.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0582.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0644.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0646.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0649.jpg)
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0651.jpg)
I then measured the distance that the bearing needed to come in on the stub axle to allow it to get as best location on the stub axle as possible.
![Image](http://i882.photobucket.com/albums/ac24/DanTurboLancer1974/Brakes%20and%20Suspension/Image0652.jpg)
