Brake upgrade
- aussiedave
Brake upgrade
Just wanting to know what upgrade you can do to the 1968 colt brakes. The discs that are standard on mine look very small and i dont know if they will hold up when im racing it. Any help would be great.
Thanks
Thanks
1970 Colt 1100f SS 4g32
Re: Brake upgrade
mate we are going to need to see some pics of what you got
hopefully there the same a a ga or a la then you might be in luck!
cheers stealth
cheers stealth
- aussiedave
Re: Brake upgrade
As far as i know they are just standard from factory Stealth but ill get some pics tomorrow.aussiedave wrote:Just wanting to know what upgrade you can do to the 1968 colt brakes. The discs that are standard on mine look very small and i dont know if they will hold up when im racing it. Any help would be great.
Thanks
Thanks
Re: Brake upgrade
yeah but whats factory on a colt
i have never seen one in real life ,so we need to work out what it is compatable with?
fare chance its the same as the la lancer or ga galant or some other early mitsi so from there we can work out a upgrade mate!
cheers stealth
cheers stealth
- aussiedave
Re: Brake upgrade
No worries Stealth i went to get some pics today but didnt have the right wheel brace ill get one tomorrow and get some pics
Cheers Dave
Cheers Dave
Re: Brake upgrade
if any one has a lancer/galant hub and disc that Dave could borrow to do a test fit. aparently they have the same size in the bearings. not sure what needs to be done to to fit the caliper
MATT
stock disc look like dinner plates
Re: Brake upgrade
Falcon, i had a 14 of an EA on it but they are to wide to fit in the back wheel well
MATT
MATT
Re: Brake upgrade
these actually look like falcon struts except for the small disk..i dont think they are stock..
Re: Brake upgrade
looks like the early l300 set up before thay went six stud
anyways mate do you have verniers to measure the stub axel?
or the expensive way i can sent you a la and a sigma hub and you can try to se which one fits
BUT it wont tell you clearances until the rotor and caliper then wheel are on !
hmm lets try to find out bearing sizes for now ,and we can go from there!
cheers stealth
cheers stealth
Re: Brake upgrade
early L300 wheels fit......anyone got some spare????????
i'll drop apart my spare front end and get some measures.
MATT
i have been told by many reliable sources that early mitsu hubs fit( LA/Galant)
MATT
Re: Brake upgrade
ok....hope this helps
outer Bearing internal measure 19mm
inner bearing internal 25mm
stub axle from base to thread 64mm
the std disc is 22.5cm across and 8.5mm thick
taking the brake caliper off to measure....................held on with bolts and nuts and you have to remove a brake line to get the caliper off
MATT
NOTE: my measuring device is as old as the Colts and may not be 100% acurate
MATT
- aussiedave
Re: Brake upgrade
Thanks alot Matt ive been a bit busy the last 2 days to do anything with the Colt but you sure did save me sometime. Much appreciated Matt
Cheers Dave
Cheers Dave
Re: Brake upgrade
i'm very interested in the answer my self
MATT
MATT
Re: Brake upgrade
alright so i pulled apart a green strut (sigma ) and there 19mm 31.75mm and different length
BUT i still have a stock la and a galant to pilfer ,my guess is its the same as the la
will pull it apart soon as i can guys!
cheers stealth
cheers stealth
Re: Brake upgrade
cheers to you stealth
MATT
MATT
Re: Brake upgrade
well here is the bad news the stub axel on the la is different again 17.4mm and 27mm ids
so now the next question is
what is the od of the two bearings and seal ?
how bigger brakes do you guys want to run and what stud pattern do you want?
are there class restrictions (parts of the eira )or go nuts ?
what is the stud pattern on the diff?
cheers stealth
cheers stealth
Re: Brake upgrade
the diff is the same 5 stud set up. early lancer diff's bolt in but you have to pump the rear guards or cut a little bit off the ends of the diff
i have had a quick look for some more modern measuring devices to do a re check but i can not find them.
for me it is something i have been toying with for a while.......to change to a 114.something( datto) stud pattern would allow a choice of wheels, the std 13X4 wheels with a 5 stud pattern are hard to find and the way the back wheel hides in the rear makes width a big problem.
how does the disc connect to the Hub on an LA( how many bolts)these have 5.
the option i went for was better linings, i got some datsun 1200 pads and cut them down to fit.
MATT
sent a message to the guy who owned Coltspeed to get more help
MATT
Re: Brake upgrade
la are a 4 stud 114.3 same as datto's
but i dare say it wouldnt be a upgrade in stopping ,just easier to get parts for
but the best way out of this is see if we cant mix a match some bearing into a hub
but if you want to upgrade the stopping performance then go to starion hubs or make billet hubs to suit what
you want to do
cheers stealth
you want to do
cheers stealth
- aussiedave
Re: Brake upgrade
Thanks for the info guys im not real good when it comes to brakes, im basically after better brake setup for stopping as im racing it on tarmac and just wasnt to sure if what i have would be good enough. So a Starion setup would fit? or would it need to be made to fit.
Cheers Dave
Cheers Dave
Re: Brake upgrade
we still need to work out more sizes first
maybe with a mix and match of bearings it might go on
but the question is what rules are you bound by in your class of racing ,and what size wheels do you
want to use "od" 15 or 13
cheers stealth
cheers stealth
- aussiedave
Re: Brake upgrade
I can do anything as im running in sports sedans and im not sure if id fit 15in under it , maybe 14in would be the go.
Re: Brake upgrade
a small bit of info i got back........you might need a drum brake front hub to install the LA hubs.
Craig from old colts has a few with drums ( if ya watching could you measure some for us)
MATT
still waiting for more emails
MATT
Re: Brake upgrade
Does a 690kg race car with less than 100hp really need a brake upgrade????????????????????????????????????????
- 77galantv6
Re: Brake upgrade
could just about use your feet lol,
i would imagine galant brakes would be plenty
sigma would have it pushing the driver through the screen.
good luck with it
by the way, where are you going to be racing it?
good luck with it
'77 Galant V6....
- amgis_obrut
Re: Brake upgrade
how is the disc fixed to the bearing hub and how thick is the disc from the rear of disc where it bolts to the hub
GC GD galant (dunno about ga gb) LA LB LC lancer and GE sigma share the same bearings
Ford transit mk2 bearing hubs fit on ge sigma stubs complete with bearing seals so will also fit galant and lancer
castlemain rod shop do a conversion kit to fit ford falcon disc's to mk2 transit stubs using a bearing sleeve this kit will also adapt falcon discs to GE stubs also converts the stub to use holden size bearings
Re: Brake upgrade
more the fact you can't get disc's for these off the shelf.......BIG26L wrote:Does a 690kg race car with less than 100hp really need a brake upgrade????????????????????????????????????????
MATT
