diffs
Posted: Sat Jul 24, 2010 6:07 pm
by rob020
hey guys,
the diff in my gh is clunking badly... what other vehicles can i swap the centre out of?
would a ge diff fit in my gh?
Re: diffs
Posted: Sat Jul 24, 2010 6:12 pm
by shuggy
you need to know your diff ratio, how many bolts is has, front or rear center (jap or BW) and then find another sigma with the same ratio, botl pattern and model as urs. there are so many variations
Re: diffs
Posted: Sat Jul 24, 2010 6:29 pm
by rob020
not fussed about ratios...
so how do you tell b/w from jap diffs? is there much differences or among jap diffs or among b/w diffs or are the differences only between jap and b/w?
centres aside... can i get the housing out of any GE, GH or GJ onwards wagon and bolt it in?
any helpfull hints to point me in the right direction?
cheers,
rob
Re: diffs
Posted: Sat Jul 24, 2010 6:31 pm
by shuggy
thats as far as my knowlege goes sorry
Re: diffs
Posted: Sat Jul 24, 2010 8:17 pm
by Superscan811
There are basically 3 types of Jap diff that will fit the GE/GH Sigmas.
2 are Jap , 1 is BW.
If the spring mounts are on the diff, it won't fit a GE, GH or Wagon.
The 2 types of Jap diff that will fit are from the GE and GH Scorpions.
The GH diff is preferable because the axles are thicker.
If you "WERE" using a BW diff and going to a JAP diff, you will need the diff, hand brake cable and all the control arms from the Scorp diff to be able to fit it.
Also, the tailshaft flange "MAY" be different.
The GH BW diff.
The GH Jap diff.
Re: diffs
Posted: Sat Jul 24, 2010 9:57 pm
by rob020
are ge and gh b/w diffs the same?
im looking at a ge sedan for a donor... will i be swapping the centres or the housings?
Re: diffs
Posted: Sat Jul 24, 2010 11:29 pm
by Superscan811
rob020 wrote:are ge and gh b/w diffs the same?
They have the same mounting points and will bolt straight in.
If the spring mount IS NOT on the diff, it WILL fit a GE or GH.
I don't know whether the axles or centers are the same but I would guess they are.
I believe the GE Scorpion Jap diff centers are probably leftovers from the pre '78 lancers and galants but I would guess they realized they weren't strong enough when pushing a vehicle with a 2.6L astron, especially if it weighs an extra 300kg when compared with the lancers.
Re: diffs
Posted: Sat Jul 24, 2010 11:55 pm
by metaldrift
GJ wagon diff definitly fits GH sedan or wagon, I did one today, full swap.
