2.6 wide block auto
morpsi91
2.6 wide block auto
Post by morpsi91 »
Hi just trying to find out if any1 has a auto to go behind a wide block 2.6 i have 2 people that no how to make them be if some1 know how to do it more simple way i would go that way
the only people that i have found to do it is
http://www.sigmalovers.com/sigmalovers_002.htm
and
(the wide block adaptor mounts the GM power glide/350/400 auto trans to the 4G64 and the G54b engine)
www.billsautofab.com
thanks rob :)
MrBishi
Re: 2.6 wide block auto
Post by MrBishi »
Import Starion/sapporo auto. 4 speed O/D. Try putting a wanted ad on Austarion.
Is it for big HP & racing or a mild street car?
morpsi91
Post by morpsi91 »
the box will be going behind a 2.6 pushing about 550hp to the wheels on NOS so yer.
all i need is a boushousing that will bolt to the wide block so i can put a converter in there
:) thanks rob
Sigmaproject
Post by Sigmaproject »
I am thinking that maybe you need something a little stronger than the OD Starion box :think:
nosakifaki
Post by nosakifaki »
I have a starion auto if you are interested.
I'm pretty sure these were also used in the VL turbo and aftermarket stuff like shift kits are readily available.
Pick up in Bendigo. $150 and it's yours,
Last time I drove the car the auto was faultless, the engine was removed and fitted to my GK GSR.
JA starion.
GK GSR Turbo.
BMW E34 540i.
billhincher
Post by billhincher »
I build GM trans adaptors for either the wide block G54b or the first and second gen 4G63 .
I added some side mounting motor mounts in my latest designs, for guys that wanted a mid plate
I used a Toyota starter with a provided pinion gear to fit the GM flywheel
these are the first heat treated couplers, they allow you to use the standard GM flywheel with the swap, keeping the price down
mic_77
Post by mic_77 »
You can use a wide block manual bellhousing to adapt a c4 with a bit of work they fit as that is the set up that was in Con's old sigma either that or if you keep leaning on it you will be looking for an auto scorpion block as the sigma block will eventually fail.
cheers Mic
mic_77
Post by mic_77 »
Or use the trans adaptor above but you may need to relieve the tunnel a bit to make it fit.
cheers Mic
