Hi all.MY BOX is leaking at the tail shaft input point
Its a manual (starion 5 speed)
What do you do to fix ?.
regards
gearbox leak
Re: gearbox leak
Fit a new seal.
Re: gearbox leak
I would also check above the tailshaft there is a small welsh plug that seals the gear shift rodleoca64 wrote:Hi all.MY BOX is leaking at the tail shaft input point
regards
I've had then come out a few times while on the track
