r154 on 4g63t
r154 on 4g63t
Hi guys ive got a gd galant and have a 4g63t engine ready to go in was wondering if the r154 fits in the gd galant easy. What modifications needed to fit this?
Thanks
Thanks
- Contact:
Re: r154 on 4g63t
I built that a couple years ago, it only requires a different throw out bearing holder ( supplied)
http://projectzerog.com/forum/viewtopic ... &start=300
this is the first R 150 narrow block 4G63 bellhousing
![Image](http://www.billsautofab.com/images/WRseriesnarwblk38_JPG.JPG)
![Image](http://www.billsautofab.com/images/WRseriesnarwblk39_JPG.JPG)
![Image](http://www.billsautofab.com/images/WRseriesnarwblk40_JPG.JPG)
![Image](http://www.billsautofab.com/images/WRseriesnarwblk41_JPG.JPG)
![Image](http://www.billsautofab.com/images/WRseriesnarwblk42_JPG.JPG)
![Image](http://www.billsautofab.com/images/WRseriesnarwblk43_JPG.JPG)
The R 154 got harder to find here and more expensive so then I went back and developed the R 150 and R 151 , that gives you a more choicesBill Hincher wrote:this is the R 154 connected to the 4G63 narrow block
Re: r154 on 4g63t
would this gearbox fit in a gd galant..
Re: r154 on 4g63t
Was your car originally manual or auto? You might fit in an auto tunnel with the aid of a 2lb hammer and a lot of swearing, not a ghost of a chance in a manual tunnel. The R154 is a pretty sizeable gearbox.
Re: r154 on 4g63t
ive seen a r154 in person, its a very large box...
would need the floor cutting out and welding in a bigger tunnel. Why are you looking to use a supra box? a g63 will easily put the power through a w58/ or a rx7 turbo box, which is what the starion race guys use, when they are over 200rwkw
![thinking :think:](./images/smilies/msn_thinking.gif)
Re: r154 on 4g63t
Problem with the RX7 'box is that the B2600 bellhousing the Starion guys use is a wideblock pattern, so you'd need an adapter to a narrow Borgy bellhousing or a complete custom bell to make it work with a VR4/Evo motor. Other than that, from talking to people that've used both I'd go RX7 box over a W-series as they're (slightly) stronger and shift better at high revs.
Re: r154 on 4g63t
ahh sorry didnt realise you were running a evo/vr4 4g63...
- Contact:
Re: r154 on 4g63t
the EVO 4 thru 9 is a different bolt pattern then the narrow block 4G63 dont get them confused I build those for the W series trans too
Re: r154 on 4g63t
My engine is a vr4 4g63t which i had in my gsr lancer and had 550 hp to all four wheels. Ran a 10.7 @ 139miles at wsid. Whats the best and strongest gearbox for street use then for my gd galant. And it is currently auto..
Re: r154 on 4g63t
What do you intend on using the car for?
Re: r154 on 4g63t
Well i want a strong reliable street car and i will take down to the track now and then.
Re: r154 on 4g63t
Are we talking straight lines or corners?
General rule of thumb (IMO) is you want an auto for drags, manual for everything else.
IMO your best bet on the manual front would be an FC3S RX7 'box or a W58 Supra 'box. Or if you feel like fabricating a new tunnel, go R154.
DO NOT go anywhere near a Celica 'box (W50-W55) as with the power you've said you're pushing it'll snap like a twig.
Re: r154 on 4g63t
straight lines. How strong are the w58 gearboxes are they good for street driving.
Re: r154 on 4g63t
W58 will last if you baby it. A stockish 1UZFE (~340hp at the fly) will break one fairly quickly if you give it a thrashing, so your motor wouldn't have much trouble breaking one.
Go auto man. You won't find many manuals that will last at that power level AND fit in the Galant tunnel. 904TF (auto Scorpion 'box) bolts straight up and can be beefed up sufficiently enough to take everything you can throw at it (it's basically a mini 727).
Re: r154 on 4g63t
where can i find one of those gearboxes.. What are they worth?
Re: r154 on 4g63t
Check out 77/78 scorpions. Used one in the first GD wagon I built. They're outrageously strong. As for price, don't know... also don't know how you're going to set up the kick down linkage from the trans to the throttle. Add a B & M megashifter to frighten passengers!
Re: r154 on 4g63t
All auto Scorpions used the 904. No, it won't handle 550hp stock, it'll need work.
