So today i found out an interesting fact, that Pre August 74 Saturns (correct me if im wrong) had a smaller clutch, since i robbed a 74 Galant for its motor i had this smaller clutch, when i ordered a new clutch i ordered for a 76 thinking there would be no difference, turns out that the clutch plate and pressure plates are different, and the flywheels between the two have their locating studs in different places, The smaller Pre aug 74 is around 7 1/4" in diameter where as the later clutches are around 8" in diameter.
Now onto my question, since i have the larger clutch i checked another motor i havbe and it has a flywheel that will suit the clutch, now i want to know if i am going to encounter any more issues if i simply switch out the flywheel to the one with the studs placed for the larger clutch??
Flywheel to suit small clutch
Flywheel to suit large clutch
any help would be appreciated in confirming i will have no issues with doing this
VGJONO
