I had to take the distributor out to replace the inlet manifold gasket, now I can't get my ute running again and I'm getting desperate. Really desperate.
I took the first spark plug out, took the dizzy out, cranked the wheel until the white line was pointing at TDC mark, then I checked with a screwdriver in the sparkplug hole and it hit something, so I"m guessing it was set right, did it again for good measure.
Then I lined up the small circle on the dizzy near the teeth with the notch on the dizzy shaft (not the pin hole, but the small circle next to it) and then I slid the dizzy back in being careful not to turn the wheel on it.
I put all the leads back on and tried to start... nothing... wont turn over
