gear reduction starter motor
Posted: Mon Oct 03, 2011 11:26 am
by ghuphill
is there a diffrence between wide and narrow block starter motors for the 2ltr sigmas ,also are there any good after market gear reduction starter motors any one has used or recomend ive seen some on ebay but thought i would ask first.
Re: gear reduction starter motor
Posted: Mon Oct 03, 2011 8:37 pm
by scorpioncollector
2ltr/2.6ltr starter the same. Wide or narrow. Have large variety of all, including reduction type
swings motors over real easy. Especially ones with little more compression than normal.
Posted: Tue Oct 04, 2011 9:24 am
by ghuphill
no problem ,thanks.
Posted: Tue Oct 04, 2011 9:33 am
by gaz914
Can use Magna starter, but it fouls the engine mount
I clearanced the mount and it works well.
Gaz
Posted: Tue Oct 04, 2011 12:26 pm
by robbert
Sigma auto is 8 tooth and manual is 9. And TS magna reduction starters throw out to far and will miss the flywheel most of the time.
I'm on my 5th starter in 20k km's and still looking for one that works. My head is getting sore from banging it on the wall.
Posted: Fri Oct 07, 2011 9:40 pm
by Rally_2.6LC
I do have a starter motor that is apparently geared down and a 'high torque' for hi-comp engines. Couldnt tell u what its off caus got it when i got the car, but it lookes exactly the same as the one from my Galant (and it fits too). I did think it was from a magna though???
Sorry not much help.
Cheers Matt
Posted: Fri Oct 07, 2011 9:56 pm
by Superscan811
robbert wrote:Sigma auto is 8 tooth and manual is 9. And TS magna reduction starters throw out to far and will miss the flywheel most of the time.
I'd guess there may be something wrong with your ring gear because I've been using the same geared reduction TR Magna starter motor on my widebloock engine, using both a standard sigma and starion flywheel, for at least 2 years.
Zero problems.
Posted: Sun Oct 16, 2011 9:36 am
by RuffDiamond
Worst case scenario you may have to modify something fit. My friend and i did that once on my old daihatsu, using a newer daihatsu armature with the old cog and old housing. It looked dodgy as hell but it lasted longer than the car did
Posted: Sun Oct 16, 2011 10:43 am
by brendon
my auto elec mentioned a hyundia starter whic bolts up to astrons an is a great upgrade.
can't remember specifics atm
