4G32 Twin Cam
dang
4G32 Twin Cam
Post by dang »
Has anybody come across gasket kits for the twin cam? Ours is nearly ready, we just need a few 'odds and ends'.
Any help would be appreciated,
Dan
2 x LA 2 Dr
3 x LA 4 Dr
1 x LB 4 Dr
2 x 4G32 Twin Cams
Rally_2.6LC
Re: 4G32 Twin Cam
Post by Rally_2.6LC »
Hoonboy use to have one, but its extremely hard to come by these now.
Ive never seen a listing in Aus for them, maybe try Japan.
Unforutnatly these engines were few and far between.
Cheers Matt
woops
Re: 4G32 Twin Cam
Post by woops »
If this post is about getting a gasket for a twincam 4g32 then it might be best to take a look at hoonboys thread on performance forums. On his post on the 25/5/07 he mentions about using a 4g37 head gasket. The rest of the bottom end might be the same as a 4g32 but i'm not sure.
http://board.performanceforums.com/foru ... 1#poststop
If you are actually trying to find a 4g32 DOHC then good luck as i have only seen 4 in australia over the last 5 years. And only 2 of them were for sale on ebay for a grand or 3
dang
Re: 4G32 Twin Cam
Post by dang »
Woops,
I have a twin cam 4G32. I thought I'd ask about a gasket kit as it'd make life a little easier not to have to have gaskets made. The head gasket is the easy one, there are a few others that are a little tougher.
Dan
2 x LA 2 Dr
3 x LA 4 Dr
1 x LB 4 Dr
2 x 4G32 Twin Cams
HoonBoy
Re: 4G32 Twin Cam
Post by HoonBoy »
Head gasket is off the shelf 4G32/37 depending on your bore size, the rest have to be made up, nothing available. The half-moon rubbers at the back of the rocker cover are available from another car, but I can't remember which one.
