MSD boost/retard system
Posted: Wed Sep 23, 2015 9:45 pm
by Paddles
Hey has anyone with a carby turbo setup used this at all??
http://www.ebay.com.au/ulk/itm/262011329444
Re: MSD boost/retard system
Posted: Wed Sep 23, 2015 10:09 pm
by Paddles
Posted: Thu Sep 24, 2015 1:46 pm
by Turbo047
Yep got the 6BTM on mine. Best mod I've done. It's been running trouble free for 10 years. But I did blow a coil a year ago. It runs better with no vacuum advance, locked machanical advance and set at 20 to 25 deg BTDC. And I also run a Magna dizzy without the module. You just solder into the mag pick up.
Posted: Sat Sep 26, 2015 9:06 pm
by Paddles
Thanks for the reply and info. What series Magna dizzy? Any pics or more info?
Posted: Sun Sep 27, 2015 9:37 am
by Sigmaproject
I once bought a Carby Magna dizzy to send to Scortcher to be regraphed and a boost retard canister fitted. When I got it back and went to install it..I found that the mounting for the module on the Magna dizzy was at a different angle to the Sigma GN dizzy, and it would not fit.
I forget what the actual issue was, but I think it was that the module was fouling the thermostat housing on the turbo inlet manifold. I had to take it to an auto electrician and have the innards switched over into my GN Astron II series dizzy.
If you run a magna dizzy with aftermarket ignition then the mounting for the module could be cut off I guess.
Posted: Sun Sep 27, 2015 2:07 pm
by Paddles
Thanks for the heads up. I'm still running a dizzy built by performance ignition but time to upgrade and have a bit more of a play with the setup.
Posted: Sat Oct 03, 2015 1:42 am
by d3v147
You could convince me to part with my setup.
Posted: Sun Oct 04, 2015 6:28 am
by Paddles
Inbox sent d3v147.
Posted: Fri Oct 09, 2015 12:53 pm
by GESigman
If you upgrade, I'd certainly be interested in the old turbo dizzy
Posted: Tue Oct 13, 2015 6:31 pm
by Paddles
I may sell. I'll let you the direction I go. Will be going with the msd system
Posted: Fri Oct 16, 2015 9:00 pm
by Paddles
Does anyone know which model Magna dizzy I would need to use as mentioned above?
Also d3v147 could I grab some more info about your setup you may be selling?
