MSD boost/retard system
Hey has anyone with a carby turbo setup used this at all??
http://www.ebay.com.au/ulk/itm/262011329444
Re: MSD boost/retard system
Yep got the 6BTM on mine. Best mod I've done. It's been running trouble free for 10 years. But I did blow a coil a year ago. It runs better with no vacuum advance, locked machanical advance and set at 20 to 25 deg BTDC. And I also run a Magna dizzy without the module. You just solder into the mag pick up.
GH Sigma Turbo no. 047
Thanks for the reply and info. What series Magna dizzy? Any pics or more info?
I once bought a Carby Magna dizzy to send to Scortcher to be regraphed and a boost retard canister fitted. When I got it back and went to install it..I found that the mounting for the module on the Magna dizzy was at a different angle to the Sigma GN dizzy, and it would not fit.
I forget what the actual issue was, but I think it was that the module was fouling the thermostat housing on the turbo inlet manifold. I had to take it to an auto electrician and have the innards switched over into my GN Astron II series dizzy.
If you run a magna dizzy with aftermarket ignition then the mounting for the module could be cut off I guess.
Thanks for the heads up. I'm still running a dizzy built by performance ignition but time to upgrade and have a bit more of a play with the setup.
You could convince me to part with my setup.
Inbox sent d3v147.
If you upgrade, I'd certainly be interested in the old turbo dizzy
RWD Mitsubishi - Love the unloved
I may sell. I'll let you the direction I go. Will be going with the msd system
Does anyone know which model Magna dizzy I would need to use as mentioned above?
Also d3v147 could I grab some more info about your setup you may be selling?
