NEED HELP! WHAT ENGINE IS THIS?
Posted: Fri Apr 10, 2015 8:31 pm
by CALM98
All i know is it is a Turbo Sirius engine, what does the ECI mean?
Re: NEED HELP! WHAT ENGINE IS THIS?
Posted: Fri Apr 10, 2015 8:55 pm
by CALM98
Posted: Fri Apr 10, 2015 9:01 pm
by BlueThunder
From your description I would say it's a 4G63 SOHC (8 valve) engine. Found in Lancer Turbo, Starion and Saporro Turbo/Scorpion. ECI stands for Electronically Controlled Injection.
PS, your link doesn't work...
Posted: Sat Apr 11, 2015 11:41 pm
by Cottees
Pics now fixed. Yep, ECI is Electronic/Electronically Controlled Ignition. Looks like a single port injected setup.
Posted: Sun Apr 12, 2015 12:31 am
by BlueThunder
I had the twin carb version of this engine in my Celeste (originally from 1982 Saporro GSR)
I think you are wrong Cottees: it's not "Ignition" but "Injection". Ignition still works with the distributor and big coil pack iso electronically controlled coil packs. On the other hand you are right: this is a monopoint fuel injection setup.
Posted: Tue Apr 14, 2015 10:34 pm
by VGJONO
So thats where that ended up. Green Sedan correct?
Posted: Thu Apr 16, 2015 8:56 am
by Scorpma82
If I had a Galant, this is the engine I'd use (albeit, I'd scrap the ECI and use twin carbies for the more 'period correct performance' and simplicity)
