Is anyone making 400rwhp or there abouts out of there 2.6lt turbo?????? If so, what turbo, fuel, injectors, head gasket, etc.... are you using?
I already have a "built" bottom end, head, cam, computer, inlet & exhaust manifold & fuel system but haven't got to the turbocharger yet...... I'm thinking XR6 GT35/40 roller bearing type turbo will give me what I need.
Thoughts & suggestions peoples........ Show me some numbers!
400RWHP..... Which Turbo?
Re: 400RWHP..... Which Turbo?
What trim wheels and housings are you using and where does it make its power?
TO4Z has a pretty broad range of options available for it......
I have a T04E with a 58mm front wheel. 30psi boost on C16 388hp at the wheels. That is through an auto and that turbo is 15 years old.
T04Z would do the job better.
I have a 2.3 TC 63 with 387 hp atw on 19psi with a plain bearing 3582 but if you want it to spool sooner then a GT3071 would be my pick FWIW
