4G52 how to remove timing chain
jack1781
Post by jack1781 »
hi all,
i am currently chainging my head gasket,
can anyone tell me how to remove the chain to get the head off?
this is the last part i need to know befor i can do it.
cheaterparts
Re: 4G52 how to remove timing chain
Post by cheaterparts »
jack1781 wrote:hi all,
there is a single bolt in the front of the cam sprocket - it take a 22 mm socket once undone the dizzy drive and sprocket come away from the cam
the dizzy drive comes off and the sprocket just sits on a seat that bolts to the top of the block
the head removes with the sprocket and chain just sitting on the front of the motor
you dont loose the cam timing or anything
jack1781
Post by jack1781 »
brilliant cheers man.
tried turning the bolt but it seems to just spin the chain,
would putting it in gear be the best idea?
