1EM0051 starter motor.
Narcotics
Post by Narcotics »
Hi I'm having some issues with my started motor not engaging. It looks quite new & tight
I thought I'd Google the part number before I started playing with the causes first
which let me to these 2 questions...
Dose anybody on here use a 1EM0051 starter?
I found this Criteria for the starter is this correct for 4G54?
Position / Degree: R 54 °
Voltage: 12 V
Rated Power: 0,9 kW
Rotation Direction: Clockwise rotation
Clamp: 15A
Number of Teeth: 8
Number of Holes: 2
source = http://www.rexbo.eu/valeo/starter-455963?c=100359
The most expensive car I've ever bought was a 1984 Mitsubishi... in 2014.
InsaneTD
Re: 1EM0051 starter motor.
Post by InsaneTD »
When you say not engaging, is it grinding the teeth on the fly wheel or not even touching it?
Call me TD.
Narcotics
Post by Narcotics »
Grinding, has not done it in a few days thought so haven't got off my arse to look at it yet.
Gonna take it off and have a look at teeth soon. I'm suspecting my flywheel is rooted, the voltage sounds to be good.
Starts really well when it doesn't grind :(
InsaneTD
Post by InsaneTD »
I'd say it's the teeth on the flywheel then. Had the same in my sigma for a while. We just turned the flywheel around and stuck it back on. Worked fine after that. If I hadn't run it off funds I would of replaced it though.
Call me TD.
