High Oil pressure
Posted: Sat Aug 10, 2013 9:49 am
by havocgtr
Hi all i have just fitted a turbo setup to my scorp and while i have the timing cover off for the balance shaft removal i put a brand new magna oil pump in it and im wondering if i need to be worried about the REALLY high oil pressure its about 80 psi at idle and at least 100 psi at revs (gauge only goes up to 100) sort of concerned it may start pushing oil past the turbo seals although the turbo is a t04B rebuilt about 500 klm ago by Ray Hall in Cairns
Re: High Oil pressure
Posted: Sat Aug 10, 2013 12:53 pm
by Superscan811
While the Magna oil pump will be able FLOW more oil, the pressure is regulated.
Basically it means that you will have GOOD oil pressure even when the engine is low in the RPM range but the peak oil pressure should be similar.
At higher RPM's, the excess oil flows back through the bypass valve, into the sump.
It's a good idea to put an oil cooler in, if possible, because the pump will put more heat into the oil, exactly the same way a turbo heats up air when its compressed.
Posted: Sat Aug 10, 2013 1:10 pm
by havocgtr
Thanks Superscan i have a oil filter (fairly big one off a rotor
) so is 80 psi idle and 100 psi driving ok oil pressure ? never had an engine run that higher pressure before
Posted: Sun Apr 06, 2014 12:03 pm
by JBSTAZ
Remember oil pressure is only resistance to flow a good motor needs app 10 psi per 1000 revs
Posted: Sun Apr 06, 2014 4:17 pm
by yno26galant
yeah my oil pressure in my n.a 2.6 astron starts at 85psi and drops when heats up down to 45 on idle. and stays around 65 to 85 on driving conditions.
Posted: Sat May 31, 2014 10:34 am
by jameslikesstuff
My oil pressure on my stock standard g32b is at the top end of the gauge all the time, is this regular, or is the oil pressure too high?
Posted: Sat May 31, 2014 12:45 pm
by yno26galant
im sure your gauge is faulty. hook up a a different gauge and it should vary in pressures when the motor is cold. to hot. then different rev range also
Posted: Sat May 31, 2014 6:07 pm
by JBSTAZ
High oil pressure is not always a good thing as pressure is resistance to flow.
10 psi per 1000 revs is plenty.
Posted: Sat May 31, 2014 6:47 pm
by jameslikesstuff
Yeah might be the gauge, it goes to the top and stays there, no fluctuation.
Posted: Sat May 31, 2014 7:54 pm
by bruggz351
This is why use a mechanical oil pressure gauge. Actually, I started having trouble with both my water temp and oil pressure in the JEEP. So I threw 'em and installed mechanical gauges along with a mechanical oil temp gauge for the auto trans.
I just find them more reliable. Only thing, with the oil pressure gauge, you do have to be mindful of the capillary and check it from block to guage every oil change for any damage, as they can fail.
Instant sump dump.
Other than that though....
Posted: Mon Jun 02, 2014 12:48 pm
by brendon
I prefer a mec gauge too and had one but I was made to swap to electric
for running CAMS events, hot liquid in the cockpit is a no no
Posted: Mon Jun 02, 2014 12:50 pm
by Scorpma82
mech guages maybe a roadworthy issue too for the exact same reason
Posted: Mon Jun 02, 2014 5:43 pm
by bruggz351
brendon wrote:I prefer a mec gauge too and had one but I was made to swap to electric
Oh cock!!!
So far I haven't been pinged,
heh heh, spose if I do, I'll stick 'em on the bonnet in a fake scoop.
aka Pontiac Firebird style.
