Hi guys
I have a magna m7 head it needs a bit of a tidy up which means $$ and flat top pistons , or do i use another magna head i know of that is ready to go with roller rocker cam and doesnt require flat top pistons im unsure ,as i want the best performance. i will be doin a cam upgrade and removing the ballance shafts at the same time im just confused now with the difernt options any help to point me in the right dierction would be cool thanks .
Which head to use
Which head to use
84 gk sigma
Re: Which head to use
do a bit of seaching on the site theres a sh!t load of info if you looknatosig wrote:Hi guys
however all astron 2 heads including all magna heads need flat top pistons or the comp is to low - I think the comp is to low even with 3 mm shave off them with flat tops ( but maybe thats just me )
if you are going to cam up your engine there is a better than fair chance you will need to fit solid slipper type rocker gear off an astron 1 head
