Ive got a turbo cam ground through camtech 238@50 113 lobe seperation. I didnt degree the cam in
. Anyways it is in dot to dot correct. As the car is together Ive only check the IVO and EVC on the balancer and the IVO @ 12btdc, EVC @20atdc (at valve with lash correct). Inlet lift atdc 28", exhaust lift atdc 49" (at valve with lash correct). It idles at 900rpm smoothly with 22 inches of vacuum. perfect for a sleeper
. Obviously by the specs its retarded. but does this seem right for that size cam? Any thoughts and experiences would be great. thanks
