Bench racing alert!
What sort of power have people gotten from their 'all motor' Saturns? No turbo, no blower, no "nawz".
I keep hearing about how the valve angle limits power...
Fast NA Saturn motor?
Re: Fast NA Saturn motor?
A couple of well-known ones within our car club are around the 85kw atw mark.
124hp atw with the old webber carb... Will re test with the twin sides later
Another member I know is at the 121rwhp mark. But all this is a bit of money.. Mine I know cost close to $4k including the carbs. It's quick for a na 1600.. But was it a wise choice? Fuel is a bitch! And if you break something.. You will have to get it custom made to suit..
There's still more I could do to it yet. Double valve springs, stroke/destroke the engine, elec ignition (on its way).
But I love it and that's all that matters
N/A ALL THE WAY
That sort of power would be fine. My benchmark is my piston-powered 808 which made 67kW ATW.
Now, to make things more difficult: What if I said that 1560cc was the absolute limit?
Then lower your sights considerably I suspect !
Both Dinta Officer's and Steve Ashton's cars are around 1800cc in a 4G32 block ... using big fat pistons (80 or 81mm I think) and increasing the stroke by offset boring the big ends.
If you gave Dinta a ring I'm sure he would be happy to enlighten you. Shoot me a PM if you want his number.
i think im pumping bout 1800cc too in my 4G32 bored out biggest pistons i can put in there and my engine compression has been put up as well can put a turbo on it or will send a piston or 2 through the block and im also running twin dellorto carbs i think 40mm from memory my little galant goes hard
Mines only 40thou os pistons.. But they're flat tops. My compression is 9.5:1
N/A ALL THE WAY
he doesnt post here very often but a member tre4oz has an insane 4g32. sounds amazing and goes pretty wel too. try pm him
