Miscellaneous
Posted: Sun Mar 04, 2012 8:33 pm
by Gazza
Hey, my name's Gary.
I'm just wondering if anyone knows where to get some various items for a 1975-4G32 fitted to an LA Lancer... (I'm not very knowledgable about anything to do with these things)
These various items include:
*'Main' Wiring Harness
*'Performance' Head, or Cam and valves/springs
*Double-Clutch
*Various 'Performance'... things
Sorry about my ignorance towards... everything I mentioned. Gotta learn sometime.
Thankyou for any replies and help...
Re: Miscellaneous
Posted: Wed Apr 04, 2012 11:33 pm
by aussiblue
Re: Miscellaneous
Posted: Wed Apr 04, 2012 11:48 pm
by aussiblue
And you will be hard pressed to find any performance parts for an engine that old; a turbo and/or a larger engine from a later model Mitsubishi would be the best alternative.
Re: Miscellaneous
Posted: Fri Apr 13, 2012 7:06 pm
by boyracer
Buy another car ....
Re: Miscellaneous
Posted: Wed Apr 18, 2012 10:22 pm
by aussiblue
You can slotted and cross drilled front disks on ebay and a Japanese car importer should be able to get you a twin car and manifold setup from a related Japanese domestic model that will fit.
eg
http://www.ebay.com.au/itm/Mitsu-LANCER ... 20c2befa27
and lowering springs
http://www.ebay.com.au/itm/Mitsubishi-L ... 1c23686978
and rear lowering blocks
http://www.ebay.com.au/itm/Mitsubishi-L ... 1c22a2840c
you can also replace the suspension rubbers with Nolathene, Super Pro or similar eg
http://www.ebay.com.au/itm/SUPER-PRO-MI ... 256f4d9c8d
Re: Miscellaneous
Posted: Wed Apr 18, 2012 11:34 pm
by aussiblue
Re: Miscellaneous
Posted: Thu Apr 19, 2012 8:26 am
by geezer101
...yeah, that'll make a good daily driver
Re: Miscellaneous
Posted: Tue Apr 24, 2012 9:00 pm
by leen
You can get most things done if you have the money.Engine can be adapted machined retro fitted, clutches, exhausts,suspension,fuel systems it just depends how far you want to go.Have a look at Hoonboy to see what is possible.
Re: Miscellaneous
Posted: Fri Apr 27, 2012 11:45 pm
by Gazza
Thanks for the helpful replies everyone...
I've sorted a fair bit of stuff out now, but I shall use this info to help me get the rest of the way
Thanks again
