LC lancer headlight conversion
Bought some aftermarket H4 halogen headlights for the lancer but with closer inspection, the originals are not the same. They have the mounting tabs spot welded to the light body itself, not a light and cup style setup like on galants etc.
Anyone had a go at modding these to fit aftermarket lights?
Needs GA or GB galant front cut to resurrect a GTO. Please help if you can
Re: LC lancer headlight conversion
I don't know if this helps but I have the Hella Housings 1024 (see http://db.hella.com.au/cgi-bin/catalogu ... lmaint=808) and the matching Hella Halogen rectangular headlights and they bolt straight in where the original housing fit and the lights are of the same dimension as the originals. I got mine from Blackwoods http://www2.blackwoods.com.au/infoBANKP ... &P=7760078
Regards Blue
Thanks mate, I'll sus it out.
I was thinking of having a dig around the wreckers for something similar but i didnt know you could buy them of the shelf
- Rally_2.6LC
So aussieblue, are these Hella's a straight swap for the original LC headlights?
Cheers Matt
Cheers Matt
Yes; they are and it means you can fit the Hella halogen headlights too. I suspect their availability is something to do with the fact that Mitsubishi used the LC Lancer headlights and taillights in so many of their truck models.
Regards Blue
- Rally_2.6LC
If people were interested here are the lenses to go with these frames.
http://db.hella.com.au/cgi-bin/catalogu ... lmaint=815
Hella part number 1043
Cheers Matt
Cheers Matt
- Rally_2.6LC
or cheaper ones that are exactly the same
http://www.ebay.com.au/itm/260728854090 ... 1439.l2649
Cheers Matt
Cheers Matt
I'm sorry for bringing this thread back sir but I just want to have a review for aftermarket H4 halogen headlights. I'll be buying this headlight for my car.
These are worth considering too http://www.ebay.com/itm/CERAMIC-H4-HI-H ... es&vxp=mtr so the wiring doesn't fail with the heat from the halogen bulbs.
Regards Blue
thank you very much for providing good headlight wiring. I'm currently searching for these..
Pretty easy to use the early Mitsi Triton headlights,just needed to relocate a spring or two because both triton buckets were the same each side.My electrician said there would be no problems...so far so good.
