HI
Does anyone know what stainless bars i can use on my lancer to replace the standard ones
LC BUMPERS
Re: LC BUMPERS
Good question , my mate is chasing similar info.
Growing old is inevitable
Growing up is optional
Re: LC BUMPERS
Chrome LB hatch bumper bars are a straight change over from memory.
Re: LC BUMPERS
The LB rear bumper fits straight on (except for the side mounts - where you will need to make your own fixing arrangements)
The front is another matter
The main mounting holes on the bar need to be slotted to move the bar upwards (about 10 - 15mm at most)
Then the mounting panel under the grille (LC grille and mounting panel is different to LB ones) needs to be "cut/bent/modified" to try to make the bar look like it is meant to fit
The side mounts will need to be fixed however you wish !
I will have mine finished in a few weeks (the bar is at the chrome platers atm) and will post some pics
So the answer is the front is not a straight change over fit ..... the LB bar was made to fit with the round LB headlights and grille panel
Lindsay
Lindsay
Re: LC BUMPERS
There is always this for the front http://market.autopartsfair.com/plymout ... s-953.html
Regards Blue
Re: LC BUMPERS
I noticed on my racecar I'm doing the body up on it its a lb Lancer hatch which I've put lc guards on it there seams to be a very slight difference in the front section of the guard but I fitted the lb crome bumper on and appears to line up with the side mounts meeting up to the guards ok.
