Looks like a boxy old heap to me LOLwebby wrote:No, that's a TR/TS, the TM/TN/TP is the really old boxy one, '85-'90 models.
The cops have been around to look at that Magna because it had been there a couple of days, so i wont be touching it.
stealth wrote:you head is a astron 2 inlet pattern![]()
so get a aussie head and go nuts cheers stealth
Sorry mate just so im clear,
are you saying my inlet manifold Will suit a m4 and m7 head??
So im ok to get a M4 head?
Im thinking ill buy a recoed M4, it will be cheaper than the crack test only to find its cracked and have to replace it anyway...
And maybe get double or just thicker valve springs?
My current cam is apparently a no.2, or stage 2 (not too sure)...
will that be able to be swapped over,
or just use the stock Magna one?
Would it be worth getting larger valves fitted for flow?
or not worth the cost?
Id just rather do it all in one hit rather than get it together and want to pull it apart again later...
Cheers everyone
