Factory Radiators
Factory Radiators
Howdy,
Has anyone come across any factory, alloy, radiators that look like they may come close to fitting in the lancer/galant engine bay? The closest i have been able to find is off an excel.
any ideas?
cheers,
Mick
any ideas?
cheers,
Mick
Re: Factory Radiators
your trying to save weight? get a smaler battery instead
no one has posted anything but you can buy new ones if you can re mortgage your house
if you really need one go to pick a part and measure or if your lucky try one in a lancer there.
you can buy a ally radiator that bolts in from PWR that are $850
but a HQ 6 cly radiator fits nice and LJ-LC with "little mods"
and you can get cheap rip offs of them of ebay for bugger all
or piss your battery and tray off and go a VQ statesman V8 there
massive though
cheers stealth
massive though
cheers stealth
Nice idea Stealth, I have pissed off my battery tray (did it to make the engine bay smoother) so I might try the big sucker
If you Google "Plymouth Arrow Aluminium Radiator" you'll find you can get bolt in aluminium radiators from North America to fit. eg http://cgi.ebay.com/ebaymotors/1979-198 ... 2011r29452 and http://www.genesisautoparts.com/all_alu ... -arrow.htm even with shipping given their light weight and low price it might be a realistic option.
Regards Blue
If you know the dimensions of the radiator find a NISSENS book and it has all the dimensions of the majority of rads.then look for a second hand one.Suck up to your local spares or workshop etc and borrow the book.There are lots of other brands as well and they all have source manuals.
HZ Just needed to cut out for the horn mounts and need to get the filler cap moved.
Yeah, old thread but I didn't know it existed, lol.
In my GC I used a EH Holden alloy rad, hoses on the right side and filled the hole perfectly.
This is the very one;
http://www.ebay.com.au/itm/High-Per-3-C ... 3a6f359c21
And here it is fitted
- greenlancer
I just took an old LA Lancer radiator down to my local radiator shop and had it re-cored – with a triple-core - for only $350! It's been 40 degrees here in Perth the last few days, and no overheating at all, even when stuck in traffic.
Now if i only had air-con!
75 LA Lancer 2-door 4G32
VR4 full alloy radiator off ebay, recently saw for $156, removed 4 rows from one side swap top outlet or run hose across never goes above normal operating temp
