Hi,
First rime to post here in Sigma-galant. I've been reading some post and learned that my car should have a 10 bolt diff, btw my car is a 79 Lambda Super Touring same as a scorpion, however when i take a look at my car it has an 8 bolter. So my question is, can I used any 8 bolter LSD from a mitsu? I've seen omeone in my area that is selling an 8 bolter diff with LSD however it uses leaf spring and drum brakes. Can i still use the ceter diff to my car? Did Mitsu realy realeased a scorpion with 8 bolt diff?
Thanks in advance
8 bolt diff
Re: 8 bolt diff
Welcome mate.
As far as I know there are no limited centres for 8 bolt diffs
Only the GH late 1979-1980 had the 10 bolt. If yours is what we call a GE 1978-1979 then it will have the 8 bolt. This is of course all based on the Australian product range, which is invariably the shittest options available compared to the rest of the world
Hope this helps.
Hope this helps.
Re: 8 bolt diff
Aaawwww...... So my diff is not that good compared to the 10 bolter. Will it be swappable? I guess the seller is just talking crap what he is selling has one.
Thanks!
Thanks!
