83 sigma parts to gd wagon
Hey guys I was just wondering what sigma parts from a 83 sigma will fit my gd wagon?
Re: 83 sigma parts to gd wagon
What parts specifically?
Some are "yes", some are "no", most of which are "will do with minor modifications"
Brakes/ struts etc need abut more handling and stopping power
I'm pretty sure they sit in the "will fit with minor mods" catergory
There has been quite a few threads on this throughout the forum, use the search button near the top of the page, it will get you your answers faster than you may think
The front struts will fit if you use the 3 bolt strut top from the Galant, and you change the 3 bolt strut base (that bolts to the lower ball joint) to the Sigma 2 bolt one.
Note, doing this will narrow your front track by approximately 40mm.
the brake disc will hit on the lower control arm (A arm.. whatever its called).75wagon wrote:The front struts will fit if you use the 3 bolt strut top from the Galant, and you change the 3 bolt strut base (that bolts to the lower ball joint) to the Sigma 2 bolt one.
77galantv6 has the later Sigma struts on the front of his GD Galant. But he also has a rack and pinion conversion. Maybe that resolved the problem?
really?????? what car he get that from....I know of a guy on here using S13 Silvia gear....and apparently the VB-L K-frame bolts onto the later Sigma's
